Bench vs. Buckets
Bench vs. Buckets
Greetings - I'm building a '54 F100 and need a bench seat . Northern New Jersey area. Anyone know of someone parting out a mid 80's and up pickup? No luck in salvage yards, pickups are usually picked clean within a day or 2 around here.
Hope I'm notbreakin any "Buyin',Tradin', swappin" rules here. PM or Email is fine
Thanks -Rich
Thanks -Rich
Received 3,101 Likes
on
No harm done at all. I moved the bench seat from the back of the garage to the front in case you were seriously interested in it. No biggie.
Fabricating tracks is a pain in the ****, since you found crummy bench seats in the boneyard, grab the tracks. Then making mounts is as easy as welding some 1/4" plate to the bottom of the tracks and drilling through those plates to your floor, using larger fender washers underneath assuming the floor is solid.
If not, you put a plate underneath the upper plates, drilling them together before welding so you can line them up properly on the floor and drill through.
Another option is to use hat nuts, i.e. nuts with a built in cast washer that's part of the nut. Push them through holes in the floorpan so the flange keeps it from passing through, then weld the flange underneath to the floorboard.
There's 20 ways of doing this that are fairly easy. Just use good hardware as ungraded bolts will snap in an accident. I always use grade eight for fabricated seat things simply because I want to stay inside the truck.
Email: gleonard@kean.edu Telephone: 973-222-6297 Ill be in Dover today. If its convenient for you, we can meet.
MiniMaul
22
09-23-2023 07:22 PM
black & blue 78/9
05-07-2017 07:00 AM
