engine block heater?
I just bought a 2007 f350 with a 6.0. i can't find the engine block heater cord?? I looked in the owners manual and it says "If Equiped"???? I thought all diesels would have a engine block heater. so i went online and built a 2007 superduty on fords website. there is now option for a engine block heater??? so what gives? do i have one or no?
Like UGA said it should be up by the passenger side tow hook/fog light inside the bumper. It will have a cover on it so don't just look for the three prong plug (someone else on here didn't notice it at first because of the cover). Only the trucks that were originally shipped to what Ford thought were "cold" states got them, unless it was ordered as an option. If you don't have the cord you can buy one from Ford, International, or from many online sources. Ford is by far the most overpriced though.
Yep the heater is already installed in the engine you just need the cord. A buddy of mine here at work says that any International heater cord with the two female contacts and the ground on the outside edge will work. He said there should be one for around $10. I bought mine before I talked to him, and got the part number I found on here and it ran me $40. My cord has a ground fault switch in it which I am sure bumped up the cost a bit.
I picked up my F250 diesel last week- same deal; no cord. Thanks to this board, I found the already installed heater element and simply ordered a power cord today. Access is super easy, as will routing the wires be. I'm taking mine to a timer and tying in a Battery Tender- then taking the 110v aft where I'll be hard wiring an outlet in/near the rear bumper with a recessed plug. Whenever it's plugged in; the Battery Tender turns on (keeping the batteries topped off and warm) and the block heater will be on a timer, going long before I wake up.
should i call ford and tell them to give me a cord for free? especially since i live in a cold state? they want about $80 for it and they can get it for tomorrow or the next day. i really don't have time to go make or search for cheaper, its gunna be cold for the next few days so i want it in and heating. what do you think?
