Tsb 7-05-04 ?
Old 03-02-2007, 03:42 PM
dieselfitter's Avatar
dieselfitter
dieselfitter is offline
Tsb 7-05-04 ?
Took truck to dealer (03 F350 6.0, 78k miles), for coolant leak and rough cold start. They fixed leak (EGR Cooler) and for the rough start they wrote "Found cylinder 2&5 eratic IC when cold. Performed TSB 7-05-04 Reprogram PCM." My question is is this the latest warming flash. Couldnt find info on this TSB. Could someone explain what this one is. Thank you. Wont know if it helped till I start it tommorow morning when its cold.
Mark
Old 03-03-2007, 05:08 AM
satcom40's Avatar
satcom40
satcom40 is offline
Here is the TSB.
This article supersedes TSB 06-22-3 to update the Service Procedure. ISSUE: Some vehicles equipped with a 6.0L diesel engine may experience white smoke, lack of power, exhaust odor, surges, running rough, or no start when cold. These conditions are caused by the injector spool valve sticking internally during cold engine operation (engine oil temperature (EOT) less than 70 °F ( 21 °C)) . The concern is typically evident following a cold start after an overnight soak at ambient temperatures below 70 °F (21 °C). and may last 3-5 minutes or longer as the vehicle warms up. The concern completely disappears after driving and the EOT is greater than 150 °F (66 °C). This concern typically occurs on vehicles with greater than 15,000 miles (24,140 Km/h). ACTION: Diagnose and address any warm driveability issues or hard fault diagnostic trouble codes (DTCs) prior to performing this TSB. Then if cold driveability symptoms still exist use the following Service Procedure. SERVICE PROCEDURE This procedure includes a FICM calibration that adds inductive heating of the injector coils to locally heat the oil in the injector to normal operating temperatures very rapidly and keep it hot until normal overall engine oil temperature is achieved. This will prevent cold spool valve sticking on all injectors. Therefore, it will not be necessary to replace fuel injectors for the cold driveability symptoms listed in this TSB. Inductive heat is active in Key On Engine Run (KOER) mode below 2500 RPM. It is tapered out from 131-167 ° F (55-75 °C) EOT, and is fully deactivated above 185 °F (85 °C) EOT.
*Printable View (70 KB) TSB 07-5-4  COLD START DRIVEABILITY - WHITE SMOKE, LACKS POWER, EXHAUST ODOR, SURGES, RUNS ROUGH, OR NO START - 6.0L Publication Date: February 27, 2007 FORD: 2003-2005 Excursion 2003-2007 F-Super Duty 2004-2007 E-350, E-450 NOTE: DO NOT USE CLICK TEST OR POWER BALANCE TO IDENTIFY COLD INJECTOR PERFORMANCE ISSUES, BECAUSE THE INDUCTIVE HEATING STRATEGY IS NOT ACTIVE DURING THESE TESTS. INJECTORS WHICH DO NOT RESPOND IN CLICK TEST OR POWER BALANCE WILL RESPOND IN NORMAL RUN MODE WITH THE INDUCTIVE HEAT CALIBRATION
This updated calibration strategy is a greater improvement than the previous post-cycle Fuel Injector Control Module (FICM) software release that cycled the injectors after shutdown (TSB 06-22-3). This strategy will eliminate the need to post-cycle the injector spool valves, and as a result will also eliminate the need to perform the E-Series wiring modification. The strategy achieves rapid heating of the oil in the injector through inductive heating of the injector coils. The Customer Information Sheet that was included with TSB 06-22-3 is no longer necessary. Customers who receive this new calibration after previously having received the post-cycle calibration (described in 06-22-3) will notice the buzzing noise at shutdown has been eliminated. This is normal, as the
NOTE: IF THE VEHICLE RUNS ROUGH OR HAS A MISFIRE WHEN THE ENGINE IS AT OPERATING TEMPERATURE, DIAGNOSE THOSE CONCERNS BEFORE PROCEEDING WITH THIS TSB.
post-cycle is no longer needed with inductive heating. Additionally, for E-Series there is no need to remove wiring modifications that were previously performed per TSB 06-22-3. Unmodified E-Series vehicles will NOT need the wiring modification with this calibration. 1. Using Module Reprogramming: FICM menu in IDS, reprogram the FICM to the latest calibration using IDS release 47.8 and higher or 48.2 and higher. This new calibration is not included in the VCM 2007.3 DVD. Calibration files may also be obtained at www.motorcraft.com. 2. If the customer previously had the Post Cycle calibration, notify them they will no longer hear the injector cycling after engine shutdown. WARRANTY STATUS: Eligible Under Provisions Of New Vehicle Limited Warranty Coverage And Emissions Warranty Coverage IMPORTANT: Warranty coverage limits/policies are not altered by a TSB. Warranty coverage limits are determined by the identified causal part. DEALER CODING NOTE: The information in Technical Service Bulletins is intended for use by trained, professional technicians with the knowledge, tools, and equipment to do the job properly and safely. It informs these technicians of conditions that may occur on some vehicles, or provides information that could assist in proper vehicle service. The procedures should not be performed by "do-it-yourselfers". Do not assume that a condition described affects your car or truck. Contact a Ford, Lincoln, or Mercury dealership to determine whether the Bulletin applies to your vehicle. Warranty Policy and Extended Service Plan documentation determine Warranty and/or Extended Service Plan coverage unless stated otherwise in the TSB article. The information in this Technical Service Bulletin (TSB) was current at the time of printing. Ford Motor Company reserves the right to supercede this information with updates. The most recent information is available through Ford Motor Company's on-line technical resources. Copyright © 2007 Ford Motor Company OPERATION DESCRIPTION TIME 070504A 2003-2007 F-Super Duty, 2003-2005 Excursion, 2004-2007 Econoline 350/450 6.0L: Reprogram The Fuel Injector Control Module (FICM) (Do Not Use With 12650D, 12650D84) 0.7 Hr. BASIC PART NO. CONDITION CODE 9E527 42
Old 03-03-2007, 05:13 AM
Bushwhacker's Avatar
Bushwhacker
Bushwhacker is offline
Originally Posted by satcom40
Here is the TSB.
When does this take effect. My dealership was not able to install this update yet.as of 2/28/07
Old 03-03-2007, 11:49 AM
pstrang's Avatar
pstrang
pstrang is offline
Got mine yesterday, 3/2/07. Dealer said they had just gotten it that morning. I didn't think I had a problem before (had the buzz flash), but wow did it run smoother on start up this morning around 20F (and no more buzz on shutdown). Just like a summer day. Of course, I run synthetic oil too, so that helps.
Old 03-04-2007, 10:08 AM
Bushwhacker
I think I will check tomorrow to see if they have it available.
Old 03-04-2007, 08:33 PM
dieselfitter
Thank you for the information, you guys are great! Cold start seems to be much smoother but it is also in the thirtys now. there is also still about a 3-5 second period of white smoke. Hopefully my average of 17MPG (Half highway, Half city driving) will stay the same. By the way dont get me wrong this is the best truck I have ever owned, I am all smiles everytime I fire this thing up!
Old 03-05-2007, 10:29 AM
johnnysF350's Avatar
johnnysF350
johnnysF350 is offline
Do you guys know if they will automatically do this flash at a regular service or do I have to be having a problem with cold starts to get it? I havent noticed a cold start issue on my '06 but most of it's cold starts are in a 55 degree garage.
xjcamaro89
2004 - 2008 F150
09-25-2010 10:46 PM
aletheuo
Aerostar
07-13-2008 10:42 PM
schumann
09-14-2005 08:46 PM
Beachbumcook
09-07-2005 12:45 PM
Quick Reply: Tsb 7-05-04 ?
