'05 f250 6.0 liter hard starting
Old 02-28-2007, 04:08 PM
kwilliamson's Avatar
kwilliamson
kwilliamson is offline
Last week my 2005 F250 6.0 diesel quit starting when the engine was warm. I replaced the fuel filters and still have the same problem. When the engine cools off it starts fine.
Any advice would be appreciated. Thanks in advance.
Tomorrow it goes to the Ford house.
Old 02-28-2007, 04:49 PM
ryaneverk2's Avatar
ryaneverk2
ryaneverk2 is offline
Welcome to FTE!
moved to 6.0L PSD section...
Old 02-28-2007, 05:55 PM
CanadaGuy's Avatar
CanadaGuy
CanadaGuy is offline
My money is riding on a leaking high pressure oil pump snap-to-connect fitting... any takers?
Old 02-28-2007, 07:35 PM
bigredtruckmi's Avatar
bigredtruckmi
bigredtruckmi is offline
I'll second the motion
Old 02-28-2007, 10:18 PM
Powerstroke_wannabe's Avatar
Powerstroke_wannabe
Powerstroke_wannabe is offline
I'll third the motion.
Old 02-28-2007, 11:14 PM
a-rod's Avatar
a-rod
a-rod is offline
From all the "no-start when hot" reading Ive done on this forum, Ill agree with the above and fourth that motion
Old 03-03-2007, 05:18 PM
kwilliamson
Well - it went to the dealer, I told them what I thought the problem was but they wouldn't fix anything. No codes. They said to call them next time it strands me and they'll tow it in. I've can look forward to two more days of down time without my truck.
Old 03-03-2007, 09:10 PM
Powerstroke_wannabe
Well that sucks. So much for "service." I don't think a leaking HPOP fitting will throw a code. Did they attempt any starts with the engine at normal operating temp? If not, no wonder they couldn't diagnose the problem.
Old 03-03-2007, 09:51 PM
kwilliamson
The tech said he warmed the engine up but couldn't repeat the problem and there were no codes. The dealership can't get reimbursed from Ford for the warranty repair unless there's a trouble code.
Old 03-04-2007, 08:40 PM
CanadaGuy's Avatar
CanadaGuy
The strange thing is, that lately I have seen a couple with STC fitting leaks that did not set a code, even after I was able to duplicate the problem. They are supposed to set a code (P2291), but I'm wondering if it may be an unknown problem with one of the flash updates that have come out...
Old 03-22-2007, 09:47 PM
kwilliamson
After three trips to the dealership and one tow, I convinced them to replace the quick connect as recommended in this thread - even though there was no DTC.
I've been driving it for a week and no further problems.
Thanks for all the help.
Old 03-22-2007, 10:35 PM
big inch's Avatar
big inch
big inch is offline
That's not true (although it is odd that it did not set code P2291). Had you brought your truck to me with that complaint on that year model truck, I would have proceeded to replace the STC fitting, and we would have submitted the claim like we have dozens of other times.
Anyway, I'm glad they finally decided to repair your truck. You shouldn't have anymore problems with that fitting.
Old 03-22-2007, 10:42 PM
Joms's Avatar
Joms
Joms is offline
After reading this....It goes to show the FTE "Family" is made of the best Tech's around
Old 03-23-2007, 03:19 AM
Industrial_dude's Avatar
Industrial_dude
Industrial_dude is offline
where is this fitting located ? is it easy to change? just in case
Old 03-23-2007, 08:36 AM
big inch's Avatar
big inch
big inch is offline
The fitting is on the back of the high pressure oil pump. The hpop must be removed to replace it. In other words, it is not easy to change.
Quick Reply: '05 f250 6.0 liter hard starting
