North Carolina Chapter Join Chapter, Leader:Benztechnc
my truck has a new nick name
Old 02-23-2007, 02:23 AM
ncfirefighter46's Avatar
ncfirefighter46
ncfirefighter46 is offline
well i got the injectors installed and and now she smokes like a frieght train, black smoke just a pouring out. so i am goign to call her ole smokey
Old 02-23-2007, 07:26 AM
SuperSnake's Avatar
SuperSnake
SuperSnake is offline
Is that good or bad?
Old 02-23-2007, 07:28 AM
SuperSnake's Avatar
SuperSnake
You home?
Old 02-23-2007, 11:29 AM
SCWIDVICIOUS's Avatar
SCWIDVICIOUS
SCWIDVICIOUS is offline
on top of ole smokey, all covered in soot,
press down the pedal, with your heavy foot.
Old 02-23-2007, 12:31 PM
2HI2CU's Avatar
2HI2CU
2HI2CU is offline
I'm with Cliff also....Is that a good or bad thing ?
Old 02-23-2007, 12:47 PM
SuperSnake's Avatar
SuperSnake
It will be interesting to Find out. Cause I want a diesel. They ain't cheap.
Old 02-23-2007, 01:04 PM
2HI2CU's Avatar
2HI2CU
2HI2CU is offline
Originally Posted by Old Tired Rebel
They ain't cheap.
I KNOW that feeling Cliff !!
Old 02-23-2007, 03:46 PM
MAKO314's Avatar
MAKO314
MAKO314 is offline
its a good thing if you want a strong diesel, wait till you see the cloud my ol truck fumes out you all better bring your gas mask
Old 02-23-2007, 04:28 PM
SuperSnake's Avatar
SuperSnake
Is it normal for John's truck?
Old 02-23-2007, 04:46 PM
MAKO314's Avatar
MAKO314
MAKO314 is offline
it only means it's running rich, he may have dirty air filter or knowing John he may have turned up the inj pump either way a smokin diesel is coooollllll.
JUST CUASE IT'S SMOKIN DON'T MEAN IT'S BROKIN
Old 02-26-2007, 06:34 PM
SuperSnake's Avatar
SuperSnake
Adam is always smoking.
Old 02-26-2007, 09:50 PM
ncfirefighter46
one way or the other i am
right now i am tring to figure out how the heck you time this thing and set it
but right now i know it has a heck of alot more power it will get up there in speed real fast and on wet pavement the axx will pass you. but the ticking has to be a exhaust leak i pray i installed a boost gauge and i can only hit 5 psi at 3000 rpm. so i know something is not right some where wish i knew more about a darn diesel and could fix this easier, then being confused if i can get the smoking under control i am chunking the air box putting on a custom ram air and bigger exhaust and try to turn up the turbo for more boost at least 13 to 15 psi. 5 psi is like huh pissing in the wind aint worth crap.
