Tire pressure?
Tire pressure?
I have a 97 F-150 short box. I bought a set of Goodyear Wrangler AT/D2 tires from Sams this a.m. (265/70/R16, up 1 size from stock). Where should I run the inflation for a decent ride and good tire wear/mileage? Door tag says 29 psi front and 32 psi rear. This seems to low. Thanks!
i got the same Goodyear Wrangler AT/D2 tires from sams, but i got the 255's... the tires say max psi is 44 and i have them right around 40 and have a pretty damn smooth ride, i wouldnt think goin down into the 30s would be such a great idea, may cause additional wear n tear. IMO i'd go with what the specs on the tires are and not the specs on the door, considering those aren't the same tires it comes with stock
asok
1999 to 2016 Super Duty
23
06-22-2011 08:30 AM
