99 Explorer - Flashing O/D Off Light
#63
#67
O/D dosen't respond
Hello Guys
I have a Ford Explorer XLT 1999 with 54K miles on it. I bought it five years ago wit less than 14k miles. Problem that I have with my O/D is when I try to activate it on the shift gear it dose not respond. Light indicator is not showing that O/D is on or off. When I drive the car I do not see the difference from the time when O/D was functioning properly. I have noticed this problem today and it bothers me. Also I have noticed when I change my 4WD to the Low the light indicator wont turn on. It works for $WD high but not for low. Can this be a blown fuse or problem with the control panel display?
<OPlease help me.
Thank you.<O
<OPlease help me.
Thank you.<O
#71
O/D dosen't respond
Thanks Matt,
Do you know how much will cost me to replace selenoids if that is the problem.
I went to AutoZone and they did code error scan and it turned to be just fine. The employee there suggested to check fuses and relays which i belive has nothing to do with this problem. I also checked for schematics on this car and it has no fuses for O/D and 4WD.
#73
