Explorer, Sport Trac, Mountaineer & Aviator 1991-1994, 1995-2001, 2002-2005, 2006-2010 Ford Explorer
99 Explorer - Flashing O/D Off Light
  #31
Old 02-26-2007, 09:50 PM
Ponyracer's Avatar
Ponyracer
Ponyracer is offline
Hey Matt, do you have the TSB on this? It could be posted on this thread and will list all the parts needed by year. I dont remember the number anymore but I know there were atleast 2 or 3 TSB's on this until they got to the molded gasket/separator plate fix
  #32
Old 02-26-2007, 10:14 PM
fordboy_52's Avatar
fordboy_52
fordboy_52 is offline
im not sure.... you guys could look them on on the FTE tsb lookup for each vehicle
Matt
  #33
Old 02-26-2007, 10:15 PM
fordboy_52's Avatar
fordboy_52
TSB 03-22-10 should cover it. The part numbers are near the bottom.
FORD: 1995-2001 EXPLORER
1995-2002 RANGER
1996-1997 AEROSTAR
1997-2001 MOUNTAINEER
2000-2002 EXPLORER SPORT
2001-2002 EXPLORER SPORT TRAC
This article supersedes TSB's 03-11-9, 02-13-8 and 02-08-2 to update the model coverage.
ISSUE:
Some vehicles built prior to 12/1/2001 may exhibit the following shift and engagement conditions:
No 2nd Gear
No 3rd Gear
No Engine Braking In Manual 1st.
Out of specification pressures controlled by the transmission main control valve body separator plate may be the cause.
ACTION:
Verify the condition, the main control valve body separator plate may need to be updated to the latest level. Refer to the following Service Procedure for details.
SERVICE PROCEDURE
CAUTION: A NEW SEPARATOR 7Z490 MUST BE USED WHEN INSTALLING THE SPECIAL SERVICE KIT 7M203 OR ADDITIONAL TRANSMISSION DAMAGE MAY OCCUR. REFER TO THE PARTS APPLICATION CHART IN THIS ARTICLE FOR CORRECT SEPARATOR PLATE PART LISTING.
NOTE: THIS ARTICLE DOES NOT APPLY TO ANY OTHER CONDITIONS OR COMPONENTS THAT MAY CAUSE SIMILAR SYMPTOMS AND IS ONLY WRITTEN TO COVER THESE SPECIFIC CONDITIONS.
NOTE: AN IN-LINE SERVICE FILTER IS NOT REQUIRED TO BE ADDED OR REPLACED FOR THIS TSB.
Verify that one or more of the following conditions exist.
Low Line Pressure While In Drive At WOT
No 2nd And/Or No 3rd Gear
DTC P0732, P0733 Or P1762
Install Kit (3L5Z-7M203-JA) to update the main control valve body assembly, refer to the installation procedures found in the kit.
Reinstall the main control by continuing to follow the installation steps listed in the Workshop Manual, in-vehicle service, main control valve body.
After completing the procedure, verify the condition has been corrected.
Clear all DTCs.
Part Application Chart
Vehicle Application Engineering Description Qty. New Service Part Use on Transmission Application 7000 -Reference Only-
95/96 Models ONLY
95/97 Models Separator Plate to Case Gasket 1 2L5Z-7C155-AA ALL
95/97 Models Separator Plate to Main Control Gasket 1 2L5Z-7D100-BA ALL
95/96 Models - ALL Plate - Valve Body Separator 1 F5TZ-7A008-CA 95GT-AA/BA/CA/DA/EA/FA/ GA;96GT-BA/CADB/EB/FA/ GA/HA/KA/MA/NA
97 Models ONLY
97 2.3L Ranger Plate - Valve Body Separator 1 F77Z-7A008-AB 97GT-GC
97 3.0L OHV Ranger/Aerostar Plate - Valve Body Separator 1 F77Z-7A008-AB 97GT-EC/FC/MC/NC/RE/SE
97 4.0L OHV Ranger/Aerostar Plate - Valve Body Separator 1 F77Z-7A008-CB 97GT-KE/LE
97 4.0L OHV Explorer/Mountaineer Plate - Valve Body Separator 1 F77Z-7A008-DB 97GT-KF/LF
97 4.0L SOHC Explorer/Mountaineer Plate - Valve Body Separator 1 F77Z-7A008-EB 97GT-AE/BE
1998-2001 Models ONLY
98/01 2.5L Ranger Plate - Valve Body Separator 1 1L5Z-7Z490-DA 98GT-GA; XL5P-CA
98/00 3.0L Ranger Plate - Valve Body Separator 1 1L5Z-7Z490-EA 98GT-EB/FB; XL5P-AA/BA
98/00 4.0L - EI Ranger Plate - Valve Body Separator 1 1L5Z-7Z490-FA 98GT-KB/LB; XL5P-DA/EA/FA
98/00 4.0L - EI Explorer Plate - Valve Body Separator 1 1L5Z-7Z490-GA 98GT-CB/DB; XL2P- EA/FA
98/00 4.0L - SOHC Plate - Valve Body Separator 1 1L5Z-7Z490-HA 98GT-AA/BA; XL2P- CA/DA
2001-2002 Models ONLY
2001/2002 2.3L Ranger Plate - Valve Body Separator 1 1L5Z-7Z490-AA 1L5P-CA
2001/2002 3.0L Ranger Plate - Valve Body Separator 1 1L5Z-7Z490-BA 1L5P-AA/BA
2001/2002 4.0L-SOHC - ALL Plate - Valve Body Separator 1 1L5Z-7Z490-CA 1L5P-DA/EA
ALL MODELS
1995-2002 ALL as Listed Above Valve Body Service Kit 1 3L5Z-7M203-JA ALL
PART NUMBER PART NAME
3L5Z-7M203-JA Valve Body Service Kit
  #34
Old 02-27-2007, 08:03 AM
nikkiree's Avatar
nikkiree
nikkiree is offline
Oh snap!!!
I found a dealer that hooked a brother up!
Thanks all again for the help. I'm going to try to do the work this weekend. I'll let everyone know how it goes!
Late,
NOF
  #35
Old 02-27-2007, 08:27 AM
fordboy_52's Avatar
fordboy_52
good luck. remember to be patient. the job will take a couple of hours. and remember... I HAD NO REVERSE when i started the truck. im not sure if i reinstalled the reverse servo incorrectly. but after i drove around for awhile it came back. it took around 10 miles of stop and goes before my truck was back to normal. make sure you do the blow off valves while you are in there.
Matt
  #36
Old 02-27-2007, 08:55 AM
nikkiree's Avatar
nikkiree
nikkiree is offline
Do I have to do the blow off valves? What if I don't?
Is there a p/n for the blow off valve?
  #37
Old 02-27-2007, 09:16 AM
fordboy_52's Avatar
fordboy_52
i would recommend it because it helps lower the pressure to prevent this from happening again. for your transmission im not sure. you could call your parts guy that helped you and tell you which part number it is
Matt
  #38
Old 02-27-2007, 09:20 AM
nikkiree's Avatar
nikkiree
nikkiree is offline
OK! I'll try that...should I just say "blow off valve"?? Is that what the part is called specifically or is that a nickname?
  #39
Old 02-27-2007, 10:10 AM
fordboy_52's Avatar
fordboy_52
you can contact this member.... http://www.discountfordpartsaty2kford.com/
yea, if you tell him you need the blow off valve that is addressed in a tsb they should be able to find out for you
Matt
  #40
Old 02-28-2007, 04:46 PM
nikkiree's Avatar
nikkiree
nikkiree is offline
I just picked up the plate...looks like the right part!!
Now, I just went in and ordered the "blow off valve"...they said it was $74??? I'm I ordering the right part??
Help again...
Thanks,
Nick
  #41
Old 02-28-2007, 09:00 PM
fordboy_52's Avatar
fordboy_52
hrm, mine was cheaper than that.... im not sure
Matt
  #42
Old 02-28-2007, 09:58 PM
nikkiree's Avatar
nikkiree
nikkiree is offline
I found it (thanks to y2kfordparts). Here is the info:
Item Number MSRP Core Price Price
3L5Z-7M203-JA $19.27 $0.00 $13.87
VLV ASY-TRANS THROT
Thanks again to all!
Late,
Nick
  #43
Old 03-01-2007, 08:44 PM
fordboy_52's Avatar
fordboy_52
hope this works for you... make sure that you let us know in the sticky in the ranger forum if it works as proof for others who dont believe it
Matt
  #44
Old 03-05-2007, 01:28 PM
randymo's Avatar
randymo
randymo is offline
FORDBOY: I sent you a PM..........would also like a copy of your tutorial. Go Wildcats......hope they make the dance!
  #45
Old 03-05-2007, 01:43 PM
ditchen's Avatar
ditchen
ditchen is offline
Originally Posted by wm_sorg
Can you please send the writeup?
I think I am having a similar issue. My 03 explorer od light is flashing. Took it in and dealer said trans is NFG. The car drives and shifts perfectly. The only indication something is worng is the light, however I did notice the TC is not going into lockup. The light came on during routine driving. Never any tc shudder, etc. Car has 74k is not run hard or used for towing.
I am thinking I will replace the valve body, etc. Any suggestions would be greatly appreciated.
Regards,
BILL
Hum, why I am hear today,
my 2000 explorer just started doing the same thing yesterday. O/D light flashing, shifts fine, no T/C lock up. I shut it off, re-start and all is well. Then about another hr of driving (city, stop and go) it's back. 81k on the clock, no hard miles and or towing done with it.
Dealer replaced valve body gasket & other misc items when I had tranny flushed, because of issues. That was less then 6month ago.
Dealer wants to charge $85 for reading the codes. I have the Ford extended coverage $50 deduct. They say that it does not cover reading the codes.
Quick Reply: 99 Explorer - Flashing O/D Off Light
