Reverse sensing system
My back up sensors went on the fritz today. When I put it in reverse, it acts as though I am right up against something and sounds a continuous tone (not beeping). I checked for dirt on sensors and nothing is there. I can turn sensors off with dash switch.
Anyone else experience this and what is the fix? I really like having them and don't want to lose the use of them
I did a little troubleshooting today from some info I found on the Ford service manual DVD I bought on EBay for 23.00 (good deal). One of the suggestions was to do just what you said, unplug one sensor at a time to try and find the bad one. I attacked it from the other end first since I wasn't sure how to unplug the connector from the sensor. I started at the connector to module located behind right kick panel. It looks like I don't have voltage on pins that should indicate voltage. Didn't have enough time to run through whole test though and it looks like connector shown in manual has more pins than mine does. ??? More to come.
Yep, the connector is right behind the kick panel but the PAM module is a little higher up. You can put your hand on it but to get to it to remove might require removal of heater duct (or whatever that big black box is under glove box) If yours doesn't make any sound, it might be harder to find.
I used the instructions from Ford workshop manual. Like I said earlier, I didn't take the time to thoroughly run through all the test points because some of the pintests called out in manual didn't match the connectors I have so I'm not going to rely on that information. Based on the symptoms I have (continuous tone), the manual suggests to check for corrosion or pushed out pins in each connector. That's my next step. If everything looks good from there, it says to install a new parking aid module(not gonna happen)
Rushmore X
05-09-2012 10:15 PM
rwhite692
1999 to 2016 Super Duty
03-25-2009 08:04 PM
