2006 F150 Electronic Brake Controller
Hi folks,
I'm embarrased not to understand this, but have come to you guys for advice. I may be using the wrong terminology but I'll try to get my points/questions across.
I have a new F150 4x4. I am also buying a 14ft tandem trailer with brakes. The truck came with electronic trailer brakes, so I am told. I have a small bag with a wiring harness about 14" long and a trailer tow relay switch/plug.
I'm trying to decypher the installation instruction from Ford. The instructions are a measley 3 page graphical story with little words. I looked under the dash of my new 150 and I see where to plug the one end of the wiring harness into the molded 6-way gray wiring connector. But I have no idea what to do with the wire-cut ends of the harness. Is there some device I still need?
Thanks in advance for all the help.
NELawnCare
Hi folks,
NELawnCare
Outstanding. I finished researching the different types of controllers. I decided to purchase the TEKONSHA PRODIGY BRAKE CONTROL v2.6 FORD 94+ HARNESS. Looks pretty simple to install now that I understand all the pieces.
Thanks again for your quick reply and helpful information.
Originally Posted by kd4crs
If you purchase the prewired harness for your particular truck, all you have to do is plug one end in under the dash and the other end into the Prodigy and you are all done except for mounting the unit. That saves you from having to do the wiring.
Thanks again for all the help.
NELawnCare
Good choice on the Prodigy. I have a gallery with some pics of where I mounted my brake controller (Prodigy). Like whitecrystal1, I also wanted to mount it where it was reachable, but I don't have the console like he does. Lots of people mount them under the dash, but if you need to use the manual lever, you'll hit something while you're trying to find it!
Originally Posted by tooldad
Has the dash angle been a problem with operation? I ask because the Prodigy specifies an angle less than 70 degrees (including any vehicle angle/grade), while I measure the dash at ~65-67 degrees. I mounted mine below the dash, but really wanted it higher for the reasons mentioned above.
fordtrkpuller
03-15-2021 06:35 PM
firewood truck
Electrical Systems/Wiring
06-02-2011 09:30 PM
FordTrucksKickGM
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
01-09-2008 03:25 PM
MustangGT221
30
08-10-2006 07:51 PM
2006, attach, brake, contollers, controller, electronic, f150, ford, hardness, install, oem, tekonsha, trailer, wire
