1999 Ford Ranger, 4x4, front hub assembly diagram
We are looking for a diagram for the front wheel hub assembly for this truck. We are also looking for the O-rings that should be installed with the front wheel assembly. Can anyone help. Wheel assembly on truck, the o-ring was left off of it, however, Ford Motor Company says it should be in there.
Hello and Welcome!
You will want to post your question in the tech forums since this one is used for introductions and you won't reach the people you want here. Click on the Forums tab at the upper left and look over the subjects. Or you can click on this link and go straight to the Ranger forum: https://www.ford-trucks.com/forums/forum35/
Good luck and enjoy the site!
rdoddio
New Member Introductions
10-05-2007 03:51 PM
