Whats A Good Muffler For 2003 F-150 Harley
IVE BEEN READING SOME OF THE POST ABOUT MUFFLERS,WANT TO ADD A FLOWMASTER, CUT THE ONE I HAVE OUT WELD IN STRAIGHT PIPE AND GO WITH IT ,JUST DONT KNOW WHAT TO DO???? I WANT A GOOD DEEP SOUND,IT HAS A DUAL INTLET DUAL OUTLET MUFFLER ON IT NOW BUT ITS NOT LOAD ENOUGH,THANKS FOR ANY HELP YOU CAN GIVE......
my truck has a 2 inlet 2 outlet muffler on it now with 1 pipe coming from each manifold to the muffler. im adding headers next week so i dont know if i want to replace the muffler i have by itself or also remove the cats??????p.s.should i replace the dual inlet outlet muffler or would i get a better sound to add two single in and outlet mufflers....
Bassani, Magnaflow, or JDM/Silverbullet catback. Those three seem to be the most popular systems available for the Lightning/Harley Davidson trucks.
They seem to be the best sounding ones, in my opinion.
A Borla system is available, and some guys have Flowmasters on their truck, but I don't like the sound of Flows or Borla's on the L's or HD's.
Whichever system you choose will answer your question about dual inlet/outlet with single muffler vs. a double muffler sustem. For example, if you choose the Magnaflow catback (which has an internal x-pipe), it is similar to the OEM setup (single muffler), whereas the Bassani catback has dual mufflers with an x-pipe just before the mufflers.
Stewart
Stewart
thanks for the info. i had the muffler removed today and two straight pipes put in its place.it sounds ok but a little too glass packie sounding thinking about adding a tube between them to see if that would help .. also its a touch bet loud and this weekend im adding headers so i may have to add a muffler in place of the pipes. any suggestions would be helpful....
Gigemags05
05-14-2015 03:35 PM
Psyclopse
1999 to 2016 Super Duty
02-04-2012 02:35 PM
