Are there any on-line microfiche sites?
Old 01-12-2007, 11:43 AM
Ghoti's Avatar
Ghoti
Ghoti is offline
1990 E250 L6.
Old 01-13-2007, 07:36 AM
subford's Avatar
subford
subford is offline
I am not sure what you are asking, I have Ford microfiche that cover from 1948 to 1999 and I can try to look something up if you cannot find it elsewhere as it takes me a while to find anything on them. Some are bad in areas on the microfiche so I can not lookup everything. I do not have a microfiche printer or any way to get the information from the microfiche to the computer.
Old 01-19-2007, 07:48 AM
Ghoti's Avatar
Ghoti
Ghoti is offline
Thanks for the reply Bill, I would like to be able to look up part numbers myself instead of having the parts store person run through the questions that are prompted on the computer without a clue as to what they're looking at. Nothing specific right now.
Old 01-19-2007, 08:08 AM
subford's Avatar
subford
subford is offline
Most auto part stores have an online lookup where you can look up their part number. Then you can take it with you when you go in the store.
Old 02-24-2007, 11:59 PM
Half-Wit's Avatar
Half-Wit
Half-Wit is offline
8th Gear
I subscribed to ww.AllDataDIY.com. It is far from being great but it does have a lot of useful info including part numbers.
Now all I have to do is fix EVERYTHING in one year so I won't have to renew the subscription !
Old 02-25-2007, 01:28 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
The fiche are available from Ford. The slides you are asking for begin in 1990, but I'm not sure of the cutoff date. Make sure you specify light truck, as there's two versions. I also have parts books and fiche, but only to 1989.
Get a hold of Ed from FTE sponsor y2kfordparts he can get them for you.
Old 02-25-2007, 01:34 AM
NumberDummy
Soak the fiche in hot soapy water, flexing them every so often. Dry them off with Kleenex, and use Meguiars PlastX on them. Use your fingers. You'll be surprised, as the hot water will remove the grime from the scratches, and by using the polish, the slides will brighten up considerably...some of the scratches will disappear or lessen.
04-13-2004 12:08 AM
11-12-2002 01:38 AM
01-14-2002 09:06 AM
03-11-2001 10:13 PM
Quick Reply: Are there any on-line microfiche sites?
