What 4bbl carb?
Old 01-05-2007, 07:49 PM
sgtrwg's Avatar
sgtrwg
sgtrwg is offline
What 4bbl carb?
I would like to put a 4 bbl carb on my flathead any suggestions as to what I should be looking for. All information will be greatly appreciated.
Bob G
Old 01-05-2007, 08:35 PM
4tl8ford's Avatar
4tl8ford
4tl8ford is offline
A 4bbl will be a little much for a stock flathead. Taking a 239cu in out to 276 with a mild cam will run nice with a 390 cfm 4bbl.
I'm not aware of any 4bbl smaller than that.
Old 01-05-2007, 09:31 PM
arctic y block's Avatar
arctic y block
arctic y block is offline
Used to see the twin duces on em in the late 50.s and up. Pop talked about em a lot. Said they really made a 50 merc move. Manifolds and carbs gotta be out there. I realize they are a bear to keep in tune but what else a gear head got to do? Laundry?
Old 01-06-2007, 07:43 PM
sgtrwg's Avatar
sgtrwg
sgtrwg is offline
Oops!!
I forgot to mention that I have a manifold just trying to figure out what carb I need. I'll start looking around to see what's out there. If a 390 cfm is the smallest I can get that I guess that will be what I'll be looking for.
Thanks for the info.
Bob G
Old 01-06-2007, 07:57 PM
arctic y block
Is it a custom manifold? As in a y block 54+ would have to have a 57+ stock manifold to take that carb I believe. I have ran T pots(56-) and they are a flaming torch or can be. If ya can run the 390 I would put in smallest jets and headers, bigger cam etc. and it may still fall on her face when ya punch it.
Old 01-07-2007, 01:29 PM
sgtrwg's Avatar
sgtrwg
sgtrwg is offline
It's supposed to be an Edmonds but there is some question as to its authenticity. It measures 3 3/4 X 3 7/8 roughly for the carb base. I thought this would be a place to start. The engine has duals and I will be looking for a cam and heads in the future.
I would put a photo up here but I can't post attachments so I'll put it in my gallery.
Thanks for the info..
Bob G
[img]file:///G:/DCIM/100_FUJI/DSCF0005.JPG[/img]
Old 05-25-2007, 12:24 PM
dffay's Avatar
dffay
dffay is offline
Carb question
If you use the Holley 390, its not a direct bolt up to the Edelbrock Manifold. There's a spacer/adapter that goes in between. Speedway and others sell it.
Bwillden24
12-20-2010 10:07 PM
83maverickf-100
02-28-2008 12:43 PM
icuhatn99
02-05-2006 10:35 PM
calazo
06-04-2004 03:12 PM
bob_a
12-30-2000 03:50 PM
Quick Reply: What 4bbl carb?
