Propane tank size
Propane tank size
Hi Guys.
I run a E150 with a factory propane 4.9l (Engine code 9)
I've got a 100 litre tank on my van, and it only gives me about 350km. (~250miles) Slowly working my way to figure out the low milage.
Can I replace with a larger or add a secondairy propane tank so I can have greater range? What's the largest tank I can "legally" mount?
Thoughts?
Thanks.
-Pauli
Thoughts?
Thanks.
-Pauli
I am not familiar with your particular set-up, but it is not unusual for the mileage to be lower when running propane. This is particularly true if yours is bi-fuel or basically a gasoline vehicle which has not had major modifications (compression ratio, timing, etc.) to take advantage of propane's characteristics.
I don't know what size tank would be legal there, but if you have a company who services propane lift trucks (as in a freight terminal), they could probably supply another tank and tell you what you could do.
not sure size is the issue. has to be the right dot tank design. I bout a 80gal for my truck and plan on running a couple 30-40 gl tanks under the bed eventually just for long trips.
Propane needs engine compression. It's well over 100 octane but lower btu. running higher compression gets more out of the fuel w/o risk of detonation due to the octane.
I believe that the supplier for the fork lift trucks could probably give this guy strong enough tanks for the road. Frankly, if he needs to go through certification from all the government bodies, he can't afford to do this. Well, it sounds like he's not in "the land of the free", so maybe he could.
The largest tank you can legally mount on your truck is an ASME (and not DOT - lift truck) tank that can be securely bolted down onto your vehicle. Sleegers and Manchester commonly make bed-mounted tanks designed for full-size pickup trucks and the largest tanks made are the 20x60 (218L / 57.6 USG) and the 24x60 (310L / 81.9 USG). You will need to check the space between the cab and the wheelwheels on a crew cab as the 24x60 may be a tight fit.
jonnybronco
Bio-diesel, Propane & Alternative Diesel Engine Fuels
03-06-2014 11:27 PM
turboman24
03-05-2007 06:28 PM
CAT_man_963
02-20-2004 09:21 PM
