5.4 Aftermarket heads
Old 12-30-2006, 11:58 AM
CF-DRG's Avatar
CF-DRG
CF-DRG is offline
It hasn't happened yet but if my 2000 5.4 should blow a sparkplug (a co-workers 4.8 in his 2003 f-150 just blew one).. Are there a good set of aftermarket heads made?.. I know alot of people put the inserts in,and unless you do all of them, aren't the other 7 still prone to blow? If the heads are flawed wouldn't it be a better idea to replace them with a better aftermarket one, or is it a BIG job.. Maybe I'm just paranoid, and it will never happen to mine .. But I would like to be ahead of the game if it does happen....
Old 03-30-2008, 10:09 AM
some_dumb_mick's Avatar
some_dumb_mick
some_dumb_mick is offline
i know modular racing makes a aftermarker head for the 2 valve that is supposed to produce 40 more horse and 70 more ft/lbs and has 8 threads for the plugs compaired to the 5 the factory used on these. they also have custom cams. i think the heads run about 1400 bucks a piece. i'm saving up to buy a set.
you can reach them at http://www.powerheads.com
hope this helps
Old 03-30-2008, 06:14 PM
LxMan1's Avatar
LxMan1
LxMan1 is offline
Those heads are a bit over the top for a heavy truck. Patriot has a set of heads that are a bit tamer for a heavy truck.
Old 04-01-2008, 02:30 AM
2000BLK54's Avatar
2000BLK54
2000BLK54 is offline
Just pull a set of stock heads and ship them to Foxlake Racing for one of their CNC port jobs. Stage 1, 2, or 3. Cams, valves, springs, whatever. They can put inserts in the 4-thread heads and they'll be perfectly fine. Stage 1 heads, stock valves, Comp Stage 1 truck cam and springs will be a good setup. Probably spend a bit less than $2800 too.
Old 04-01-2008, 08:04 AM
Big Bad's Avatar
Big Bad
Big Bad is offline
No such thing as an aftermarket 2V head save for the FRPP/SVO castings (which are far and away the best 2V heads ever made), all of the companies are just working over and performing valve jobs on stock Ford NPI/PI castings. They do nothing to address the spark plug theads.
Just get your hands on a set of 04+ model year heads with 8 spark plug threads or install the timeserts.
And Patriot heads suck, they cut the swirl dam (reducing compression and swirl, forcing you to run a ton of timing) and can't seem to get the valve guides right. As 2000BLK54 says, Fox Lake all the way. The have a MUCH better porting program and excellent quality control.
Old 04-03-2008, 10:34 PM
ReAX's Avatar
ReAX
ReAX is offline
That's what I've noticed, only ported OE heads no aftermarket castings. If I were to go through the trouble of using OE heads, I'd start with 4v and I think it's a navigator intake.
Lonestar Apps
10-25-2013 08:28 PM
EAnton
Modular V8 (4.6L, 5.4L)
16
10-21-2012 06:03 PM
lbrowne
06-19-2011 05:43 AM
allen07ford150
2004 - 2008 F150
13
11-21-2010 12:14 PM
40LUTZAG
09-28-2006 09:46 PM
Quick Reply: 5.4 Aftermarket heads
