Explorer, Sport Trac, Mountaineer & Aviator 1991-1994, 1995-2001, 2002-2005, 2006-2010 Ford Explorer
differential fluid level on 02' explorer
Old 12-19-2006, 09:01 PM
RA81222's Avatar
RA81222
RA81222 is offline
I took the fill plug out on my rear diff. of my 02' explorer and fluid beagn to pour out so I quick put it back on.I was on perfectly level ground.I was under the impression it should be just at the fill hole.I am going to change it and the book calls for 3.25 pints of fluid plus the friction modifier.Any insight on why the fluid level is so high?
Old 12-19-2006, 10:22 PM
steve(ill)'s Avatar
steve(ill)
steve(ill) is offline
there is a big plug, maybe a 3/4 inch square drive head, on the back of the pumpkin that is the drain plug... on the driver side toward the front nearer to the drive shaft is a smaller plug about half way from the bottom to the top of the case. it has a 3/8 inch suqare drive hole to remove it. the small plug is the fill, the big plug is the drain hole. it does hold almost 2 quarts of synthetic 75w 140 oil and 7 ounces of the friction modifier.
Old 12-20-2006, 05:01 AM
RA81222's Avatar
RA81222
RA81222 is offline
Thanks-I see the drain plug and the fill plug is on the back side just above and to the right of the drain plug.I was just wondering why fluid would run out of fill plug?It should not be pouring out of there unless it is overfilled, correct?
Old 12-20-2006, 09:21 AM
Steina's Avatar
Steina
Steina is offline
CO River Rat
Had you just driven it, or did you check it cold?
Steve
arimaman
04-12-2014 10:47 AM
BASSHUNTER
6.4L Power Stroke Diesel
33
07-30-2010 10:03 AM
F250WVO
11-22-2009 04:06 PM
xlt4wd90
Aerostar
06-20-2006 10:46 AM
Quick Reply: differential fluid level on 02' explorer
