Filtering bio
Old 12-18-2006, 10:50 AM
mongo75's Avatar
mongo75
mongo75 is offline
Filtering bio
How do you guys filter your WVO? I've seen the 100 and 200 micron filters that fit on 5 gal buckets. Since I don't plan on making a lot, will these work, or is there a better way? Also, I'm looking for the right filter to use from my reactor drum to the holding drum, and should there be another filter from the holding drum to the fuel tank?
Old 12-18-2006, 08:56 PM
fabmandelux's Avatar
fabmandelux
fabmandelux is offline
Since I use an "open" style processor I use an expanded metal basket to filter out the "large" pieces before the oil goes into the "heater-precleaner" then a 1/16" punch plate screen between the Heater-precleaner and the mix tank. I filter out the soap after methanol recovery with a 5 micron bag filter [McMaster-Car # 5162K12], and use the same filter to remove the Magnesol. Final filtering is done with a 1 micron absolute bag filter [ McMaster-Car # 5162K71].
The first 2 filterings are done with an "open" filter. The final filtering is done in a closed housing [MacMaster-Car 5168K177].
All the filter bags are dumped out, and then washed in the wife's washing machine.
Old 12-18-2006, 09:52 PM
adambomb's Avatar
adambomb
adambomb is offline
i want to get a system like THIS. a cheaper alternative would be something like THIS
newguy399
10-02-2016 12:27 PM
carchub
13
08-07-2014 03:27 PM
K.Ray
03-20-2014 09:49 AM
Eric21477
04-29-2006 08:08 PM
mouse777
02-08-2006 09:22 PM
Quick Reply: Filtering bio
