vacuum diagram for 351m
Old 12-12-2006, 08:28 PM
77f150351m's Avatar
77f150351m
77f150351m is offline
does anyone have a vacuum diagram for a 1977 351m in a 2wd f-150
Old 12-12-2006, 09:55 PM
Mil1ion's Avatar
Mil1ion
Mil1ion is offline
Sure do
Can you post me the info from the Engine IDent sticker on the passenger side valve cover ?
Old 12-14-2006, 05:51 PM
77f150351m's Avatar
77f150351m
there is only a sticker on the drivers side valve cover that has the valve lash and says that it is non-catalyst
Old 12-14-2006, 10:53 PM
Mil1ion's Avatar
Mil1ion
Mil1ion is offline
Okay
Please reply with:
DSO code
AC or non-AC
Axle ratio
Transmission type
although I do suspect this diagram applies to your truck.
I just need verification.
http://www.clubfte.com/users/mil1ion/7_72J_R11.jpg
Old 12-19-2006, 08:56 AM
rebelred41's Avatar
rebelred41
rebelred41 is offline
Wink
Does anyone have a vacuum line diagram for 1978 F250 351m? Ex took my truck apart and trying to get it running right again. Chilton manual doesn't cover all the lines. Have it all together now except running a lil rough, not sure if it is the lines hooked up wrong or carb adjustment. Have adjusted the carb the best I can get it and can tell a have maybe 1 or 2 lines hooked up wrong....sure could use some help from one of you guys out there. Please e-mail a diagram if you have one...Thanks.
Old 12-19-2006, 04:35 PM
Mil1ion's Avatar
Mil1ion
Mil1ion is offline
Welcome to the site
I'll be happy to supply you with a diagram and probably an illustration.
However,
Maybe Re-read the previous posts and declare what your info is.
saying 1978 F250 351M is NOT enough info as per my previous replies.
Also, maybe start your own thread so an other person thread doesn't get confusing.
EDIT:
an auto trans will be diagram code 7-72-R11
manual trans will be 7-71-R10
Old 12-21-2006, 09:47 PM
Mil1ion's Avatar
Mil1ion
Mil1ion is offline
an Vacuum line Illustration for your truck is now in my emission album in my gallery.
Old 01-02-2007, 08:46 AM
rebelred41's Avatar
rebelred41
Thumbs up you are an angel
Thank you for assistance. Will be working on my truck during lunch hour...keeping my fingers crossed this is the one. Will let you know the outcome. Big Red needs to get some mud on the tires...It is an old fire dept. brush truck. By the way, it is an automatic.
chizzy matt
07-07-2012 06:11 PM
bluecrewman
32
10-21-2010 07:49 PM
craighardy
10-12-2010 06:17 PM
781504wd
10-16-2003 07:04 PM
snow991025
10-08-2002 11:19 AM
Quick Reply: vacuum diagram for 351m
