SVO heater line size?
Old 12-02-2006, 08:38 PM
bio-d's Avatar
bio-d
bio-d is offline
Question SVO heater line size?
I'm installing a Plant Drive SVO kit in my 87 6.9, using a 26 plate heat exchanger, Vormax filter/water separator and a 10" Hot Fox oil pickup.
They normally use 3/8" hose teed into the heater hose. Have any of you used 1/2" hose in your installations? I expect to be driving in very cold weather.
Old 12-02-2006, 09:15 PM
willbd's Avatar
willbd
willbd is offline
I have a kit from Greasel that uses ½ inch lines. The system is a hose on hose with a transmission cooler used as the heat exchanger is the front tank and a Racor 6120 with heater installed in the clear filter bowl. Filter on my 95 powerstroke. I added an arctic fox mid ranger inline fuel warmer to the standard kit from Greasel. I would recommend you checking out the arctic fox fuel heaters.
I have had no fuel related issues with this setup.
Note: Greasel changed their name to Golden fuel system.
http://www.goldenfuelsystems.com/pro...stems_ford.php
Old 12-02-2006, 09:41 PM
bio-d's Avatar
bio-d
bio-d is offline
Thanks Willbd. I wasn't sure if all the restriction of the heat exchanger would negate the larger hose size.I saw some of the more advanced Hot Fox tank pickup heater units after I had already ordered mine. They are similar to the basic coolant in- coolant out and fuel out units like mine except they have a fourth connection to connect to an external heat source.
I have another question: Where's the best location for my fuel temp sensor?
I have a Vegtherm just prior to the IP. I was going to put it just after the Vegtherm.
Mike
Old 12-02-2006, 10:39 PM
willbd's Avatar
willbd
willbd is offline
I have don't have a fuel temp sensor on my system. I switch over when the engine gets up to temp. I have checked the fuel temp with a thermometer and my fuel is @ 165 F down stream of my arctic fox heater. This is before the fuel enters the 18 feet of greasel hose on hose fuel line.
bungeekord
03-29-2016 06:02 PM
Mjr Minor
03-06-2008 12:37 PM
masscommuter
Large Truck
08-12-2006 07:42 PM
jeff moon
01-31-2003 04:00 PM
Quick Reply: SVO heater line size?
