tuning propane carbs
Old 11-22-2006, 10:39 PM
darrin1999's Avatar
darrin1999
darrin1999 is offline
im building a 545 to run on propane and was wondering how hard it is to tune the dual quad setup id need to get enough flow for the engine. any tips besides the old exhaust gas analyzer and playing with settings?
Old 01-02-2007, 05:55 PM
IB Tim's Avatar
IB Tim
IB Tim is offline
Site Administrator
...bump.....
Old 01-15-2007, 03:15 AM
roger dowty's Avatar
roger dowty
roger dowty is offline
yes...go here.... http://www.propaneguy.com/
and ask him....??
Old 02-02-2007, 09:38 AM
fraso's Avatar
fraso
fraso is offline
Air-valve propane carburetors like the Impco 425 supply fuel based on air flow and not load. The only external fuel mixture adjustments on this type of mixer are full-throttle power and idle mixture. Ideally, you put a CO analyser in the tailpipe and adjust the power mixture screw so that the full throttle CO reading is 1.5% to 2.0%.
It is always safer with propane or natural gas to go lean rather than rich. Rich mixtures burn exhaust valves because gaseous fuels do not have the evaporative cooling effects of liquid fuels. Since the air valve only senses air flow, you will likely find that your fuel economy will improve if you adjust the power valve to be on the lean side. The only danger from lean fuel mixtures is a lean misfire. Lean fuel mixtures (as with gasoline) burn a bit slower which means you will need a bit more spark advance. Once you've found a lean fuel mixture that still runs satisfactorily, try adjusting the spark advance to improve your fuel economy.
The best guide to setting up either the Impco 425 or the OHG X-450 mixer is Franz Hofmann's Diagnostic Guide. It is available on his web site for a very reasonable price.
Obviously, for a dual quad setup, you need to make identical adjustments to each carburetor.
Old 02-02-2007, 11:48 AM
darrin1999's Avatar
darrin1999
thank you i picked up his guide about a month ago and read through alot of it, but havent been able to put it into practice as yet. im looking at buying a house right now so vehicle projects have kind of been put on the backburner, but i appreciate the input
joey2fords
Bio-diesel, Propane & Alternative Diesel Engine Fuels
04-14-2014 12:06 AM
El Camino Man
07-23-2013 09:30 AM
Opossum
Alternative Fuels, Hybrids & Mileage
09-20-2012 05:53 PM
rolltide3006
06-28-2010 03:57 PM
swpete
06-11-2008 08:53 PM
Quick Reply: tuning propane carbs
