2003 F150 Fuel Filter
Old 11-21-2006, 12:22 PM
lkey32's Avatar
lkey32
lkey32 is offline
I don't normally work on my truck, but I am wanting to change the fuel filter. I have a 2003 F150, 4.6L. Where is the fuel filter located in relation to the engine? How easy is it to change it myself?
Old 11-21-2006, 12:34 PM
galaxie641's Avatar
galaxie641
galaxie641 is offline
It is on the inside of the frame more or less under the drivers door. You also need a special fuel line tool to release the clamps. Get the metal one from NAPA it works better than the plastic ones. They can be hard to get off and you may need to spray WD-40 in the fitting and spin the tool in it a bit to get the filter to come off.
Old 11-21-2006, 05:22 PM
steve(ill)'s Avatar
steve(ill)
steve(ill) is online now
welcome to the FORD forum Ikey. If you dont know what your doing, changing th efilter can take a couple hours the first time. I would buy it at Aoto Zone or other auto store and talk to the counter guy for a few minutes. This is not a screw driver and hose clamp job. THE new filters have 30-50 psi pressure inside and the fittings are a push on compression fitting. You do need a special "tool" to get it to come loose. They can be difficult to get apart.
Old 11-21-2006, 05:41 PM
LxMan1's Avatar
LxMan1
LxMan1 is offline
You will also need to bleed off the pressure in the system before removing the lines or you will have fuel spray everywhere!!!
Old 11-21-2006, 09:13 PM
galaxie641's Avatar
galaxie641
forgot about the pressure, easiest way is to remove the fuel pump fuse and crank the engine over a few times. You will still get fuel on you but the pressure should be relieved.
Old 11-22-2006, 06:49 PM
JH6's Avatar
JH6
JH6 is offline
I just pull the filter off.
Just watch your eyes, gas won't kill you.
pjohn192
12-19-2023 10:45 AM
bobkonaben
1999 to 2016 Super Duty
04-11-2015 05:43 PM
blackestate
05-06-2014 09:23 AM
Jnas860
10-28-2011 08:36 PM
2XExpy
07-22-2004 01:28 PM
Quick Reply: 2003 F150 Fuel Filter
