I have a 4.6 now that it's cold The truck starts missing in overdrive on up hill at 60 to 65.The hills from valley to anc .Turn off od runs fine ,Whatsss up
what is your gear ratio in the rear axle you just may be at too low RPM, its possible anyway or you may just be hitting ice and then pavement on the incline. does this happen on any incline or just this one? if its just that one try another incline and see what happens.
on any incline, no ice on the road, If I keep my speed up Like 70 run fine I like going the speed limit,gear ratio? It is a stock truck from ford I think they would put the right rear end in but never know .
do you have any check engine light? it is possible that you have a bad coil pack and it is arcing to the side or a air leak around the intake or a hose...
