1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
How to disable automatic door lock feature???
Old 11-13-2006, 09:31 PM
DYNAMICSPORTS's Avatar
DYNAMICSPORTS
DYNAMICSPORTS is offline
I have a 2003 F350 and hate that the door locks itself when you engage the vehicle to drive. This is not a minivan where such safety features are necessary. Can anyone tel me if there is a way to re-program the the ECU or whatever is controling this feature so that the door will not lock automaticaly?
Old 11-13-2006, 09:33 PM
GroverDill's Avatar
GroverDill
GroverDill is offline
My 06 has how to disable in the owners manual.
Old 11-13-2006, 10:03 PM
Headviking's Avatar
Headviking
Headviking is offline
I took this right out of the manual. I think this is what you want to do.
Todeactivate/reactivate the autolock feature using the keypad Yourvehicle comes with the autolock feature activated. Todeactivate/reactivate thisfeature: 1.Electronicallyunlockthevehicle.
2.Turntheignitiontothe3(OFF)position.
3.Closeallthedoors,liftgateandcargodoors.
4.Enter the 5-digit entry code.
5.Press and hold the 7•8. While holding the 7•8, press and release the 3•4.
6.Releasethe 7•8. The horn will chirp once when the system has been successfully deactivated. The horn will chirp twice (oneshortandonelongchirp)when the system has been successfully reactivated. To deactivate/reactivate the autolock feature using the power door unlock control You must complete Steps1-7 within 30 seconds or the procedure will have to be repeated. If the procedure needs to be repeated, you must wait 30 seconds.
1.Insert the key and turn the ignition to the 4 (ON)position.
2.Press the power door unlock control three times.
3.Turn the ignition from the 4 (ON) position to the 3 (OFF)position.
4.Press the power door unlock control three times.
5.Turn the ignition back to the 4 (ON) position. The horn will chirp.
Old 11-13-2006, 10:39 PM
DYNAMICSPORTS
Thanks, just changed it works great ! ! !
NitroTy19
Electrical Systems/Wiring
03-17-2016 04:06 PM
SturgeonHunter
01-06-2014 02:41 PM
joiseystud
13
01-16-2011 08:53 PM
mtatum
06-02-2009 12:09 PM
ag-ford-4x4
08-12-2005 06:38 PM
Quick Reply: How to disable automatic door lock feature???
