propane conversion
Old 11-03-2006, 12:19 AM
wesh's Avatar
wesh
wesh is offline
propane conversion
i have a 75 ford f-250. just wondering what it would take to convert it to propane. Ive also heard about a propane/gas combo and that u can run both depending on if you need more power or not. what would it roughly cost and what kind of power lose might be expected. and what kinds of modifications need to be made.
Old 11-03-2006, 01:25 AM
Torque1st's Avatar
Torque1st
Torque1st is offline
Posting Legend
Hello- Welcome to FTE! I have moved your post to the specialized forum we have here for your question. Check out the list of tech forums we have on FTE. There is a wealth of information and expertise here to help you. Check the links at the bottom, and the menu bar at the top, of the page for more information and resources. Have fun!
Old 11-04-2006, 12:30 AM
o7dgm's Avatar
o7dgm
o7dgm is offline
try www.propaneguy.com and www.autopropane..com they have a lot of info.
Old 11-05-2006, 04:23 AM
darrin1999's Avatar
darrin1999
darrin1999 is offline
it all depends on how many modifications you want to do what it takes... the absolute minimum is a mixer, evaporator, lockoff, coolant splitters for the evaporator, vapor line, service line, and a tank- can be had at propaneguy.com for about 600 dollars. you should get your distributor recurved and advance the timing a bit- encouraged but not absolutely necessary. if you dont modify the engine to run propane exclusively by increasing compression youll lose somewhere around 10% power and mileage. if you make it a dedicated propane engine then you can actually gain power and get about the same mileage if not slightly improved
oreocreaming
48
02-21-2010 02:25 PM
phatkat
02-21-2008 02:01 PM
fishindave11
04-22-2007 10:34 AM
73strokin
Bio-diesel, Propane & Alternative Diesel Engine Fuels
10-29-2006 01:23 PM
bjornb
Alternative Fuels, Hybrids & Mileage
03-01-2005 11:27 PM
Quick Reply: propane conversion
