Gas station warning for Diesel
Old 10-31-2006, 09:22 AM
eigenvector's Avatar
eigenvector
eigenvector is offline
At the pump I saw a warning sticker on the diesel pump indicating that 2007 cars will be unable to use this particular fuel. What's that all about? Is diesel undergoing some radical change in 2006/2007?
Old 10-31-2006, 12:11 PM
EPNCSU2006's Avatar
EPNCSU2006
EPNCSU2006 is offline
Going from low sulfur to ultra low sulfur. All the 07 stuff is designed for the ultra-low sulfur fuel.
Old 10-31-2006, 01:15 PM
eigenvector
So what is a 2007 car supposed to do at the pump? I'd be plenty miffed to pull into the station, only to find out they only sell low sulfur as opposed to ultra-low sulfur.
Old 10-31-2006, 04:31 PM
EPNCSU2006's Avatar
EPNCSU2006
We rented an 07 F250 for a club trip to ohio a couple months ago and had the same issue. We checked the owners manual and it said the engine would operate on both low sulfur and ultra low sulfur fuels, so we went ahead and filled up even though the warning said not to. It was that or get stranded between Raleigh and Akron.
Old 11-01-2006, 03:42 PM
pitrow's Avatar
pitrow
pitrow is offline
All the talk I have seen lately shows that the stuff you get at the pump will be fine in any vehicle. Yes, they are reducing the amount of sulphur (used as a lubricant) in the fuel, but are required to add aditional additives (wow, three in a row!) to counter-act that before it gets sold.
http://www.epa.gov/otaq/highway-diesel/index.htm
http://www.clean-diesel.org/vehicle_performance.html
Owners of 2006 and earlier model year diesel-powered highway engines and vehicles may use Ultra Low Sulphur Diesel (ULSD) or Low Sulfur Diesel fuel during the transition period. Only ULSD fuel will be available for highway use starting on December 1, 2010.
Under typical operating conditions, there should be no noticeable impact on overall power using ULSD fuel. Fuel economy may be reduced slightly because the process that removes sulfur also can reduce the energy content of the fuel.
Engine and vehicle manufacturers expect ULSD fuel to be fully compatible with the existing fleet, including 2006 and earlier model year vehicles. In some instances, the introduction of ULSD fuel to older vehicles may affect fuel system components or loosen deposits in fuel tanks. As part of a good maintenance program, owners and operators of existing cars, trucks and buses are encouraged to monitor their diesel-powered vehicles closely for potential fuel system leaks or premature fuel filter plugging during the change-over to ULSD fuel.
Like Low Sulfur Diesel fuel, ULSD fuel requires good lubricity and corrosion inhibitors to prevent unacceptable engine wear. As necessary, additives to increase lubricity and to inhibit corrosion will be added to ULSD fuel prior to its retail sale. With these additives, ULSD fuel is expected to perform as well as Low Sulfur Diesel fuel.
Old 11-04-2006, 01:07 AM
o7dgm's Avatar
o7dgm
o7dgm is offline
Sulfur is not a lubricant. The process for removing the sulfur also removes some of the lubricating qualities of the oil.The sulfur combines with water to make sulfuric acid.It has no real benifit to the fuel.
Old 01-02-2007, 07:06 PM
Tom-O's Avatar
Tom-O
Tom-O is offline
Yes, I agree. I believe that sulphur is a natural component of diesel fuel. The sulphur in diesel is a big contributor to pollution. I believe that's why the new government mandates for low sulphur fuel. However, removing the sulphur calls for extra manufacturing/refining processes, so that's why it wasn't done in the past I believe.
In other words, there's no real reason for the sulphur being in the fuel other than it's just there naturally.
Old 01-02-2007, 07:15 PM
fellro86's Avatar
fellro86
fellro86 is offline
The main reason the sticker is there is for the models that have particulate filters in the exhaust. If you were to run the low sulphur fule through the particulate filter, it would fill up and no exhaust flow, shutting you down. Many of the 07 vehicles do not have the particulate filter, so they can run both. At this time, the OEM's are having trouble getting it to work, so they aren't running the filters on all vehicles just yet. Have to see on the 08's. Eventually it will happen. It's about the same as the switch to unleaded.
Ruikee
05-11-2007 04:26 PM
sgrol
10-11-2006 06:40 PM
mahd776
08-21-2006 12:06 PM
jeem
31
06-30-2006 10:48 AM
knight60626
18
05-23-2006 09:23 PM
Quick Reply: Gas station warning for Diesel
