2000 V8 5.4 Ford F-150 Firing order.
Old 10-30-2006, 01:03 PM
valiantski's Avatar
valiantski
valiantski is offline
Hello All,
Can someone please post the firing order of 2000 F-150 V8 (5.4L) engine. Thanks.
Old 10-30-2006, 01:50 PM
LxMan1's Avatar
LxMan1
LxMan1 is offline
Welcome to the forum
Do you want the actual firing order or where the cylinders are located?
4 8
3 7
2 6
1 5
front
Old 10-30-2006, 07:09 PM
valiantski's Avatar
valiantski
reason I asked for the firing order is because I got a P0306 Code and description for that is "Cylinder 6 Misfire Detected." Isn't spark plugs firing order corresponds to each cylinder? If not, I need the location of the cylinder. Also, If you have an idea of which I need to look on first, for the issue I'm having, I'll really appreciate that. The vehicle all of sudden started shaking and lost power. I was even pulling a boat when it happened. It runs so bad in low rpm and will smooth a little bit out and be driveable with high rpm (atleast 2500 rpm). Went to AutoZone today and they lend me their scanner and I got P0306 "Cylinder 6 Misfire Detected." I haven't start doing anything yet, but leaning towards the spark plug, then the coil. But I can't even find the spark plug and don't have a trace as this engine (V8 5.4) don't seem to have a regular spark plug wires. If someone can also help me locate where the plugs are, it will be highly appreciated. Thanks.
Old 10-30-2006, 08:11 PM
astroo's Avatar
astroo
astroo is offline
The plugs are under the cop's, which are coil packs that are on top of each plug. Also, there are no plug wires, just the wires whic attach to the cop's. The plugs are just outside each fuel rail on each side. It can be rather tricky to get to the plugs. Good luck.
Allen
Old 10-30-2006, 11:33 PM
Racerguy's Avatar
Racerguy
Racerguy is offline
valiantski take a look at https://www.ford-trucks.com/forums/1...ur+spark+plugs
Welcome to the forum Allen
Old 10-31-2006, 07:53 AM
02 LariatFX4's Avatar
02 LariatFX4
02 LariatFX4 is offline
I would bet anything that it is your coil....I had the same thing happen a few yrs ago and that is exactly what it was...it was the #8 coil...a real p-i-n-t-a spot to boot...you just have to take off the fuel rail and can access them...not so bad really ...took me 30 minutes and had never done it before...
Old 10-31-2006, 08:05 AM
valiantski's Avatar
valiantski
Thanks Guys, I will update you guys soon as I get a chance to work on it, most probably this coming weekend. Again, thanks a bunch.
Old 10-31-2006, 08:09 AM
valiantski's Avatar
valiantski
One more quick question, based on the spark plugs/Coils firing order, is the #6 would mean Cylinder 6? Because code I'm getting at calls for "Cylinder 6 Misfire Detected" and I wanna make sure that I will be working on the right plug and coil. Thanks and hope to hear from you guys soon.
Old 10-31-2006, 08:21 AM
Racerguy's Avatar
Racerguy
Racerguy is offline
A P0306 is for #6 cylinder.....the second one back on the driver's side.
Old 10-31-2006, 09:04 AM
valiantski's Avatar
valiantski
Hi RacerGuy,
From this firing order:
4 8
3 7
2 6*
1 5
Front of the vehicle.
Please verify if this correct. Thanks.
Old 10-31-2006, 09:39 AM
Racerguy's Avatar
Racerguy
Racerguy is offline
Yes that's right.
Old 10-31-2006, 06:09 PM
Warren F-150's Avatar
Warren F-150
Warren F-150 is offline
You do not have to take the fuel rail off to change plugs or COP.
Old 10-31-2006, 06:16 PM
Munky's Avatar
Munky
Munky is offline
Yeah I'd bet it's the coil. Mine did the same thing except the 2 cylinder and I replaced the coil and no problems since. Just remember when you replace it, you can disconnect the negative cable on your battery for 10 minutes to reset the SES light.
Old 11-02-2006, 07:27 PM
valiantski's Avatar
valiantski
Thanks Guys! I just fixed the problem and yes, it was the "COP" # 6. Cleared the code and when i started the engine can tell right away that problem was gone. Drove it few miles in the freeway and i'm glad that it is back to normal now. Again, thanks for all your input.
Old 06-14-2009, 04:26 PM
tezra12's Avatar
tezra12
tezra12 is offline
I am having the same problem on my truck. 2000 f150 v8 5.4. Code read that cylinder 2 is misfiring and I can definately feel it. I think I might have had some bad gas in it plus the tank was just about empty when this started. I'm not sure if that has anything to do with it or if it was just a coincidence in timing? Any tips or pointers you can give me before I dig in? Are the plugs worth the difficulty of getting them out, or should I just take it in? Thanks... Tom.
Quick Reply: 2000 V8 5.4 Ford F-150 Firing order.
