hi, the vin number on my truck is found by looking at the lower of the front windscreen, from the outside of the truck. i had to use a light to be able to read it clearly. hope this helps. bokker.
Sprry, but Im´m talking about the engine number, not the code no the VIN. I hve a pair of 302, it has a plain area (or plain boss, don´t know the correct term in english) to identify that block.
V6 has some similar area where some numbers on fabrication plant could be stamped?
