8RT engine parts available
Old 10-26-2006, 09:49 PM
ksmith203's Avatar
ksmith203
ksmith203 is offline
Smile 8RT engine parts available
I went to check on my 8RT block which was being magnifluxed at the engine shop. The block was cracked so its junk. I still have all the parts that came off the engine. If anyone needs any of these parts pm me and we will make arrangements to get the m to you. I don't want to throw them in a dumpster if someone else can use them. I can be reached at 330.353.0605. I live in Massillon Ohio about 55 miles south of Cleveland. Hopefully these parts can help someone out. I was upset because this is my second flathead I tore apart. Now I tore a flat 6 a 7HA motor apart. It will be magnifluxed tomorrow.
Old 10-27-2006, 10:11 AM
soule46's Avatar
soule46
soule46 is offline
Too bad you are so far away. I could use the water pumps, so that I have something to rebuild. I could also use some valves and guides. Bummer.
Old 11-06-2006, 09:21 AM
SteV8e's Avatar
SteV8e
SteV8e is offline
Most flathead blocks are cracked. Did you investigate repair? I've seen threads on this forum regarding evaluating a crack's repairability (can you see both ends of the crack?). I've heard tell of a shop that was selling blocks (with repairable cracks) that they were scrapping for customers. Some have said that the cracks are latent features in these flathead blocks.
projectmater
15
11-07-2014 01:16 PM
ksmith203
03-03-2013 01:49 PM
ksmith203
10-02-2009 11:22 AM
ksmith203
19
04-10-2007 08:55 PM
ksmith203
20
10-30-2006 08:42 AM
Quick Reply: 8RT engine parts available
