79 F-150 Fuse Diagram
Old 10-23-2006, 05:46 PM
idgit0488's Avatar
idgit0488
idgit0488 is offline
Where can I get a diagram of the fuse panel? My brake lights, tail lights and reverse lights are all out.
Old 10-23-2006, 06:05 PM
Mil1ion's Avatar
Mil1ion
Mil1ion is offline
If the horn works I suspect the NSS on the transmission is really dirty causing the B/U lights not to work........common problem
Old 10-23-2006, 06:09 PM
idgit0488's Avatar
idgit0488
Awesome! Thanks man.
Old 10-23-2006, 06:25 PM
rboeding's Avatar
rboeding
rboeding is offline
If the fuses are good check the ground. I replaced my ground cable this weekend with one that had a little pig tail on it with a spade. I bolted it to a near by bolt. The lights are brighter and the turn singals are stronger and everthing electrical runs the same at idle or at speed. Don't underestimate the ground.
Old 10-24-2006, 10:54 PM
idgit0488's Avatar
idgit0488
when you say ground cable, are you referring to the negative battery cable? Just want to clarify because I saw the tailights have ground wires coming off of the back of the bulb fixture. The wires were in good shape and had a solid ground.
Old 10-24-2006, 10:58 PM
idgit0488's Avatar
idgit0488
What is an NSS? Where about would it be located on a C6?
Old 10-25-2006, 12:01 AM
Mil1ion's Avatar
Mil1ion
Mil1ion is offline
NSS = Neurral Start (safety) Switch.
It is located on the side of the transmission.
Old 10-25-2006, 09:48 AM
idgit0488's Avatar
idgit0488
What would you recommend to clean it with? I've got some carb and brake cleaner in the toolbox...
Old 10-25-2006, 01:13 PM
Mil1ion's Avatar
Mil1ion
Mil1ion is offline
coatesgirl4
41
03-17-2019 07:26 PM
centralNH
18
04-11-2014 05:36 AM
73AlgonaMom
02-19-2014 12:37 PM
beaable
Electrical Systems/Wiring
11-05-2007 08:55 PM
yjtrendsetter
1997 - 2003 F150
02-24-2002 06:39 PM
Quick Reply: 79 F-150 Fuse Diagram
