429 Fuel Pump Eccentric
Old 10-09-2006, 09:23 PM
tommyleea's Avatar
tommyleea
tommyleea is offline
I know this is a simple question, but I must ask. I replaced the timing set on my 429. Can the fuel pump eccentric go on in any position. I see no marks, and the book just says to install it. I didn't mark it when I removed it. It seems odd that nothing holds it in place except the cam gear bolt. TIA..Tommy
Old 10-11-2006, 10:28 PM
tommyleea's Avatar
tommyleea
I guess it isn't a simple question..
Old 10-12-2006, 12:42 AM
monsterbaby's Avatar
monsterbaby
monsterbaby is offline
well usually the eccentric as a tap that sticks down that goes into the hole where the pin for the cam stick into the gear to keep it from spinning other than that there is no real set position for it to be in.
Old 10-12-2006, 07:53 AM
tommyleea's Avatar
tommyleea
I agree with that, however; there was no hole or tap on the eccentric. It is just a smooth solid plate except for the bolt hole. Thanks for the help though.
Old 10-12-2006, 08:06 AM
greenhighboy's Avatar
greenhighboy
greenhighboy is offline
The early one piece eccentrics didn't have the tab. Just bolt it on and it will work fine.
Old 10-13-2006, 08:59 AM
tommyleea's Avatar
tommyleea
Thanks for the info..Peace of mind..
rcfreed
06-26-2015 01:20 AM
stercorarius
04-07-2015 06:30 PM
tbakko
10-05-2012 10:13 AM
medino03
05-14-2012 10:24 AM
Quick Reply: 429 Fuel Pump Eccentric
