North Carolina Chapter Join Chapter, Leader:Benztechnc
Ford Duraspark
Old 10-07-2006, 08:43 PM
tanman722001's Avatar
tanman722001
tanman722001 is offline
Ford Duraspark
Have any of you guys put this set up on a older truck?I have a diagram.Just not to sure about it.Im doing it to my 71.It is almost ready to get it running again.But I have to get this wired up first.Let me know if you can help me figure it out.Thanks Tony
Old 10-07-2006, 09:35 PM
a11budman's Avatar
a11budman
a11budman is offline
Hey Now,
Sign on to yahoo or AIM...I know a little bit about the Duraspark
EDIT....Going to hit the sack now...just holler anytime and I'll be glad to help ya out...
Old 10-07-2006, 10:57 PM
fellro86's Avatar
fellro86
fellro86 is offline
It isn't all that hard to wire up. I'd have to go look again for absolute accurate info, but I can say that the two wire plug to the box is the 12 volt and 9 volt supply, then you have the wires to the distributor and coil. Cranking voltage to the box is 12 volt, and the run voltage is 9 volt.
Old 10-19-2006, 03:06 PM
PerfDistIgnition's Avatar
PerfDistIgnition
PerfDistIgnition is online now
FTE Sponsor
If you decide to get a new distributor, consider our D.U.I.-Davis Unified Ignition or our custom curved Duraspark distributor. Please see them at:
http://www.performancedistributors.com/forddui.htm
__________________
FTE Sponsor
Performance Distributors
www.PerformanceDistributors.com
Old 10-19-2006, 04:23 PM
5_labsownus's Avatar
5_labsownus
5_labsownus is offline
Received 1,489 Likes on 1,393 Posts
The site below describes how to go HEI! I did this to my 300 I6 and it works very good and IMHO it is easer to wire than converting to DS II.
NOTE: you must bypass the resistor wire on the ignition wire. It has to have 12V not 9V.
www.gofastforless.com
Old 10-19-2006, 09:37 PM
SCWIDVICIOUS's Avatar
SCWIDVICIOUS
SCWIDVICIOUS is offline
im thinking about doing this to my 65
Old 10-22-2006, 12:49 PM
ncfirefighter46's Avatar
ncfirefighter46
ncfirefighter46 is offline
i know me and me dad use to but this set up on our older trucks and i think we had to hook up on to the switch side of the (sil) and on to the coil. but the coil hat to changed to a electronic one. and it worked fine, i just use the old points on the older models i know the points up buy now are the cheap ones but you can still get the old good sets for under 20.00 made by borg warner and accel still have the ones made with the fiber board not the plastic. so i use the old style and i get about 6 to 10,000 miles out of them before replacing
HappyJack
Kansas Chapter
11-16-2012 09:21 PM
smash fascism
15
04-27-2011 01:31 AM
UnderTakr
Kansas Chapter
10-01-2005 02:34 PM
Tony1974
06-14-2005 09:48 AM
70T351W
06-02-2005 06:39 AM
Quick Reply: Ford Duraspark
