Bio-diesel and Diesel Kleen ?
First off, if this has been posted before, I apologise(sp?). I did a search and didn't find anything.
I bought my first tank of B-20 yesterday. It was only 2 cents more expensive than regular diesel so I figured I might as well try it out.
My questions are:
1) Is Diesel Kleen compatible with bio-diesel? Do I even need it? I've always added 16 oz. to every tank full (except in winter). I didn't add any this time in case it wasn't.
2) What about using anti-gel in the winter? Any special considerations I should know about when using bio-diesel in cold weather?
Thanks.
Howard
My questions are:
Thanks.
Howard
My questions are:
Thanks.
Howard
My questions are:
Thanks.
Howard
FABMANDELUX.
How's about a B5 blend would you still add a little Diesel Kleen??
Experiment. Try different ratios. You may find you don't need it but you may also find you get a little better MPG if you do. The key is to document. That's why I use the oil I do and change it when I do and why I buy my fuel and additives where I do. It may or may not be the lowest cost per gallon (or quart in the case of oil) but over time I've found a combination that offers a lower total cost of ownership.
Just my 2¢.
jimbo
Just my 2¢.
jimbo
Originally Posted by FARM69
Wait, I always thought bio gelled up something terrible in the winter months?
FABMANDELUX.
I'm pretty sure it depends on what kind of bio your using. I've done a little research on it and it seems like the soy gells at a higher temp than others. Which sucks because a lot of machines use it and for the tax break we get. Running DK will help it from gelling, but as far as 80% bio I don't know how much you will have to tank mix.
Hmm... Thats very strange. Its nearly impossible to run soy diesel here in the winter (in Iowa). I still have about 45 gal to use up so I'm getting a little concerned since I have no big trips in the future. Maybe its the kind of bio? Just a thought.
Any bio will be ok if you blend #1-#2 with it. Just put some in a jar with a thermometer in it, and put it in your fridge. Check it often and when you see it just start to cloud up, you've found the gel-point. Try different blends till you find a mix that stays cloud free at the temp you need and you are set.
FABMANDELUX.
