Spark Plug Torque 5.4
I am sure this has been beaten to death but I was looking and could not find the proper info about proper spark plug torque for the 5.4 motor. What would be the proper torque for the plugs and is there a certain procedure to do this? Also was wondering what type of plug every one has been useing? I currently have a 2000 f-250,crew cab, 5.4 Triton motor, with 85000 miles on it and thought that a new set of plugs before winter would be a great idea. Also does anyone use either anti seize or thread locker on the plugs since there is only 4 threads that hold them in, any ideas would be greatly appreciated.
Thanks
Tim
Thanks
Tim
As stated by our non sparkplugger friend ! That is the correct torque spec.
We use never sieze on the plugs ,we also change all boots when in there they can prevent misfires .Also we use dielectric grease on the end of the boot going over the plug ,then a little dielectric grease around the lip of the boot that seals to the head .This helps repell moisture and any water splash from getting down in the plug hole.
We also stick with the stock plugs ,because these engines seem to not like aftermarket brands.
ZRich
ZRich
Thanks, Forty. You're right about that. I'm afraid too. Think I'll see if the O.E. plugs will go that 100,000 that Ford promised. Those buggers look awfully hard to get at in the back. And with all that delicate torque and few threads, I'll just wait awhile. Edit:::::::And you're also right about those boots that Dad wore.
when I was at the dealership for the last recall , i asked the mech doing it about the plugs backing out , he told me that the plug holes are tappered to allow a machine to load and torque the plugs at the factory and that when using a standerd socket that the socket may bind in the holes making it feel like the pkugs are torqued but in fact they aren't. he said they make aspecial plug socket for the 5.4 that is tappered to fit the hole to provide the proper torque.
I saw on another site that the spark plug companies themselves are recommending that a hole chaser be used to clean the threads of carbon before installing new plugs. They say that the newer oxygenated fuels make 5 times more carbon than the old fuels and this builds up on the threads. Then when you go to torque it you are only crunching it into the carbon so you dont have the real metal to metal torque you need and this also makes the plug overheat and next she blows.
I would say that most people just do it by feel. I would say that finger tight plus a half turn would be good. Most spark plugs have crush washers that seat to the head, it is not really critical to have it torqued perfectly. Just dont strip the plug, make sure it threads in finger tight first. Also check the gaps yourself, and use Anti-seaze on the threads of the plug. This is a life saver for the next time you are changing the plugs.
Special Spark Plug Tool
I bought this special spark plug removal/install tool from Sears (www.sears.com) and it helped a lot ($37 + s/h + tax):
KD Tools 3 pc. 5/8 in. Extended Universal Spark Plug Socket Set + case
Sears item #00942274000
Mfr. model #KDS41740
3 piece 5/8 in. extended universal spark plug socket set. Unique design includes 5/8 in. spark plug socket, universal joint, and extension in one piece. Allows for ultimate access while staying securely attached to the drive tool. Includes 4, 6, and 11 in. lengths in a blow mold storage case.
Also, depending on the year of 5.4L you have. The newer ones have 3 valves per cylinder (24 valves total that create 300 hp) and require a different spark plug, which might require a different type/size of tool.
Also remember to not change spark plugs in a hot/warm engine. Several mechanics have told me to change spark plugs on an engine that sat overnight cooling down. The colder the better. Changing spark plugs in a hot or even warm engine will increase the chances of stripping out the threads - since the newer style heads are made of aluminum. Make sure to use your torque wrench (approx. 15 ft/lbs) when installing plugs.
Also, the newer style spark plug wires (if you can call it that) do have a boot with a spring inside and all connected to the coil pack. Usually these boots are very reusable and do not give any problems.
