Rear Suspension alternative
I'm planning my rear suspension, and I have a few questions. My plan is to use nascar truck arms with a 9" using air bags. I'm wondering if I could use a rear trailing arm crossmember for a 60-72 chevy/gmc 2wd truck, since it uses the same type of trailing bars. Does someone have access to a 60-72 chevy/gmc truck to take some measurements for me ? I need to know the width and heigth of this crossmember, and the distance between the ears that the trailing arms get bolted to.
Another alternative is to build my own crossmember, but if I could use a stock piece from another truck, even though it is a chevy, I'd like to go that route.
Thanks
Thanks
I don't have a lot of fabrication skills under my belt, which is why I was leaning towards an existing design.Truck arms are essentially two 51" long arms which attach to the rear axle in a similar manner leaf springs attach, then attach to the crossmember located midway up the frame similar to an a-arm on a typical front suspension. There's a set on ebay right now for pictures, search for nascar truck arms.
Sounds like an interesting project. If no one chimes in with the GM measurements that you need try the Stovebolt forum;
http://www.stovebolt.com
They are a pretty decent group also. It seems like there was a couple of featured trucks in Custom Classic Trucks or Classic Trucks not too long ago (6 months or so) that had Nascar style trucks in them. The one I remember was a 38 Ford
Good luck
Bobby
Good luck
Bobby
That's what I'm using for trailing arms, The NASCAR ones. I'm probably going to be forced to use a 2 piece driveshaft now, since it appears as though the hole in the crossmember was set up for this. The trailing arms have bushings that are approximately 1/16" too long, but they should fit snugly with a little persuasion.
I may have backed myself into a corner. The driveshaft appears to be too far to the passenger side to do this. I dont have my 390 sitting in there yet, but I'm using a volare front suspension with the nascar trailing arms and the 9" which the pinion sits about 2" to the left. The crossmember is set up for a center exit with the trailing arms attaching too close to be cutting a whole lot away.Lynn
Where there's a will there's a way, modifications are the norm when building Hot rods. Do you have pictures? Are you offsetting the engine for the Volare? Many with Volare's off set the engine a couple inches to the right for steering shaft/header clearance. That may produce more clearance issues than the pinion offset. 2" at the rear axle does not angle the driveshaft a whole lot at the tranny, but if it is tight, there are ways to get more room. How far behind the front universal is the crossmember? How far apart are the arm mounts?
