Explorer, Sport Trac, Mountaineer & Aviator 1991-1994, 1995-2001, 2002-2005, 2006-2010 Ford Explorer
Horn and Horn relay location on 1999 explorer xls?
Old 09-17-2006, 09:49 AM
Dirt1dobber's Avatar
Dirt1dobber
Dirt1dobber is offline
Question Horn and Horn relay location on 1999 explorer xls?
Just purchased a 1999 explorer xls and the horn doesn't work,does anyone know where the horn and the horn relay are located on this vehicle?
Old 09-17-2006, 10:30 AM
scucci's Avatar
scucci
scucci is offline
Horn is left front of vehicle below bat- remove wheel well apron or get to it from underneath the chassis. Horn relay is in the fuse box on the wheel well. Horns are a common failure item.
Scucci
Old 09-17-2006, 10:38 AM
Dirt1dobber
Wanted to thank you for the info,i'll check it out,hope it solves my problem!
Old 09-23-2006, 03:12 PM
Dirt1dobber
Thumbs up Thank You
Wanted to thank you for the horn relay info, found out there was no relay in the fusebox,installed a new relay and it worked,saved me the trouble of tearing the truck apart to get to the horn. Thank You!
bobiker
05-11-2014 07:32 AM
rhcdjr
1999 to 2016 Super Duty
05-08-2010 01:30 PM
oskie
01-27-2006 12:38 AM
country boy
11-08-2002 04:30 PM
Quick Reply: Horn and Horn relay location on 1999 explorer xls?
