Alaska Chapter Join Chapter, Leader:
Moving to Alaska Which Fuel is better
Old 09-12-2006, 04:46 PM
Terry M's Avatar
Terry M
Terry M is offline
Question Moving to Alaska Which Fuel is better
Hi Everyone,
I have a quick question. I am in the process of purchasing a truck in advance of moving to Alaska. Besides an engine block heater that I know that I will want to add on before I move, what fuel is the most common and cost efficiant. I know that disel is popular because of the lower freezing point but want more information.
Thank you
Terry
Old 09-13-2006, 12:07 AM
mlb4966's Avatar
mlb4966
mlb4966 is offline
During winter months most stations will only sale #1. You can use #2 but I would suggest an addative to ensure it does not freeze. Staydane or Powerservice (white). The other question is were are you moving to? Winter varies depending on were you are. I live in the balmy tropic (Coastal) were cold is usually not an issue. If you are living/moving to the colder regions consider an oil pan heater, front bra, battery heater and even an oil pan heater on your tranny. Another option is an programable auto start device. The higher end ones can be programmed to start up your truck when it COLD and run them for a preset time then shut down. It will cycle through that until you turn it off. Hope this help.
dadgonebroke
18
10-17-2016 12:59 PM
terry Bogart
06-30-2016 12:54 PM
dadgonebroke
15
06-17-2015 07:54 PM
tboss619
12-28-2008 09:22 AM
tk1251k
Aerostar
11-28-2007 05:21 AM
Quick Reply: Moving to Alaska Which Fuel is better
