Transfer Case Shifter Knob Removal
Old 08-16-2006, 10:34 AM
StinkyD's Avatar
StinkyD
StinkyD is offline
Transfer Case Shifter **** Removal
Trying to get the shift **** off, doesn't show anything in the Haynes manual. Is it threaded on or pressed on?
Old 08-16-2006, 10:58 AM
wassabe's Avatar
wassabe
wassabe is offline
I'm almost certain its pressed on because I can pull the **** off on my 88. The shifter dosn't have any threads but I think its grooved to prevent movement. I just went out and tried to pull the **** off on my 97 work truck, but its too tight. You might try hitting it from the bottom up to break it free. Good luck
Old 08-16-2006, 11:00 AM
StinkyD's Avatar
StinkyD
StinkyD is offline
I'll giver a try, thanks
Old 08-16-2006, 02:05 PM
SAlexander's Avatar
SAlexander
SAlexander is offline
Not threaded. It pulls off with great difficulty.
Old 08-16-2006, 02:54 PM
Josh88Ford's Avatar
Josh88Ford
Josh88Ford is offline
it looks kind of like a gear. You can prolly turn your **** to loosen it.
Question...why are you taking it off?
I took mine off a while ago because i am carving a duck head out of wood for the ****. Havent touched the thing for at least 2 months though
Old 08-16-2006, 09:48 PM
StinkyD's Avatar
StinkyD
StinkyD is offline
I was trying to get the boot off so I could pull the carpet out. Kinda spilled some Diesel Kleen behind the seats so I needed to give it a good cleaning. Ended up just removing the whole shift arm from the linkage. All good now. Thanks for the replys
countrydriven
06-28-2020 08:22 AM
schmiddw
09-24-2016 10:31 AM
DaveF-250SD
1999 to 2016 Super Duty
11-15-2015 12:26 AM
Shadowrider123
09-08-2014 04:56 PM
1988XLT2002
1978 - 1996 Big Bronco
10-01-2002 11:28 PM
Quick Reply: Transfer Case Shifter Knob Removal
