E4OD problems help with troubleshooting please
Old 08-15-2006, 07:47 PM
true blue's Avatar
true blue
true blue is offline
I searched for a while but could not find my problem.
When cold the transmission works perfect.
When warm; the transmission shifts perfect with light throttle. At 1/4 to 1/2 throttle it slips between all gear shifts. When shifting it just kind of hangs there then lunges into gear. It is worse at the 2-3 shift. At full throttle it shifts fine. Once it is in a gear it does not slip and pulls fine. On the highway it pulls fine you would never know there is a problem. Some times right before it shifts into the next gear the rpms will jump up very quickly before shifting in solidly seemingly like it goes into neutral for a brief second.
Any ideas? I have no maintenace records.
Old 08-16-2006, 05:57 AM
Cuda_jim's Avatar
Cuda_jim
Cuda_jim is offline
Mine acted just like yours right b4 it went south.
Do the easy stuff first. Check oil level (hot), change the ATF & filt. Take it to a tranny shop, most will scan it for free.
You might want to try a sonax/tricumulator kit if you change the ATF/fiter. It helped fix the 'hanging' shifts. Search this site for sonax, you'll find a couple sponsors that sell the kit.
Old 08-16-2006, 06:02 AM
true blue's Avatar
true blue
That is what I was afraid of. Thanks for the tip.
Old 08-16-2006, 06:13 AM
true blue's Avatar
true blue
I found the link. Here it is if anyone else needs it. Good step by step photos too.
http://www.blackclouddiesel.com/Ford...ion/sonnax.htm
Old 08-18-2006, 05:29 PM
trike1946's Avatar
trike1946
trike1946 is offline
Cuda is right on. Mine did the same thing.
Old 08-18-2006, 08:49 PM
true blue's Avatar
true blue
Did yours go south too? Is there any since in trying the sonnax?
Was there any good warning before it took a dump?
Old 08-18-2006, 10:51 PM
VargasB's Avatar
VargasB
VargasB is offline
Mine to was acting up like that and then went south on us during a trip. We just got it back from the rebuild - now the rear end of the suburban, 1/2 ton, we used to tow back the trailer (over it;s limit) is starting to whine and I had to replace a pinion seal, and maybe now who knws what else.
Old 08-19-2006, 06:24 AM
trike1946's Avatar
trike1946
Yes. Mine took a dump too. You might try it, or you might be prolonging the agony. Did you take it in for a scan?
Old 08-19-2006, 02:45 PM
bodabdan's Avatar
bodabdan
bodabdan is offline
I don't mean to sound like gloom and doom, but my e4od acted very similar before it failed. I suggest pulling the pan and checking for metal. If it's starting to come apart and you continue to drive, you could possibly damage the case. It's not cheap to repair one right, and not just any shop can do it well. If you go for a reman unit avoid Phoenix. If you can afford it you should check out some of the premium units that are available.
Old 08-19-2006, 09:11 PM
true blue's Avatar
true blue
I just made a 1,000 mile round trip with the truck empty. The transmission is acting the same. I am going to pull the pan either tomorrow or Monday. I need to face the facts. The transmission has 200k on it. I do not know the history of the truck but it looks like the original. There is no indication at that it has been out. I am preparing to rebuild or buy one. If I can swing I will get a transmission from a supporting vendor.
If I need to which is better; A Ford reman or a Jasper reman? I am new to Huntsville and I do not know of anyone reputable for a rebuild.
Old 08-19-2006, 10:58 PM
VargasB's Avatar
VargasB
VargasB is offline
My info that I was able to get when I was checking around here in Colorado was to stay away from the Ford remans if possible - too many were failing with those I checked on here in Denver. I landed at Detroit Transmission specialists and am glad I did. They did a full rebuild and update, cheaper than purchasing a new one or rebuild with a three year warranty - nation wide - I ran mine fully loaded over the Rky mountains this past week and it ran better than it has before.
Old 08-20-2006, 10:10 AM
true blue's Avatar
true blue
How much did it run you?
Old 08-20-2006, 03:37 PM
Cuda_jim's Avatar
Cuda_jim
Cuda_jim is offline
My tranny was $2089, but, I removed & installed it.
Had all high performance parts put in including:
New steel 6 pinion planitaries (front & rear)
New solenoid pack
ect, ect.....
New aftermarket (local guy) 4r100e HD converter, not reman.
I had a reputable (e4od) rebuilder do the labor $350.
Man what a difference!
I love it, but haven't towed yet, can't wait tho.
Old 08-20-2006, 08:22 PM
VargasB's Avatar
VargasB
VargasB is offline
$2500 on mine, total rebuild, with Updates, Tugger Kit and custom torque converter that they ahve built and welded up on thier own - they did it all, I just had it dropped off and then picked it up. A rebuit was $2,800 plus labor ($3,500 at the Ford dealership). At the shop they ahd a dealership delievery F250 that had shelled out the Ford rebuild that the dealership had placed in it for themselves - whcih they proply had to have the company I was using pull and rebuild the right way and reinstall). so far I am really pleased - we took it out this weekend again and it shifted like a charm
Old 08-20-2006, 08:23 PM
true blue's Avatar
true blue
I wish I could find a deal like that here locally.
6.0 and 7.3 United
13
09-04-2022 01:49 PM
Dustinlen87
1999 to 2016 Super Duty
10-06-2016 06:45 PM
brolandscape
10-30-2015 02:30 PM
-Ross-
09-20-2013 03:33 PM
LSO1123
04-23-2011 07:05 PM
Quick Reply: E4OD problems help with troubleshooting please
