WVO/pump Mix
08-15-2006, 03:38 PM
on
WVO/pump Mix
Can you mix wvo and pump diesel together? I dont see why you couldnt, but would it thin the wvo out a little more or would it all just seperate?
08-15-2006, 08:42 PM
The local rocket scientist says it'll seperate. One will burn then the other. That could turn out bad when you end up burning the VO without having the fuel system prepped for it.
08-15-2006, 10:49 PM
on
