Idle problems..Surges up and down?
Within the last couple of weeks, my 2001 Expedition (4.6L) has had some idle issues...
When I am in drive, and come to a stop, like at a red light, the engine seems to surge up and down. This doesn't happen when in park, only when in gear, and is starting to worry me.
What is this a symptom of?
thanks alot
thanks alot
Might be IAC. Check out this thread from the Explorer Forum:
https://www.ford-trucks.com/forums/1...pair-help.html
Also check out this recent thread:
https://www.ford-trucks.com/forums/5...-ac-is-on.html
I was reading in my Chilton manual last night how the IAC works with the A/C. Sounds more and more like an IAC.
Please let us know if/how you fix this problem.
Thanks!
Thanks!
Originally Posted by Thrower20
I am having the same issues with my 98'. Could it be the TPS, I read the voltage and the closed position reads .05 higher than the top end of the range. Any ideas or should I be looking into the IAC also.
Rodney
120K, 5.4L, 3" w/ a 50 series Flowmaster, UNI Filter
Rodney
I happen to have a brand new TPS. I'm gonna throw it on this weekend and I'll let you know what happens.
If that doesn't fix it, I'll replace the IAC.
Originally Posted by ghman
where is the iac located on a navigator?
https://www.ford-trucks.com/article/...r_IAC_Fix.html
jrgrtx
07-26-2017 05:06 PM
