1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
06 F250 horn location
Old 08-09-2006, 09:27 AM
tlamshooter's Avatar
tlamshooter
tlamshooter is offline
O.K. guys, I searched the threads about adding horns, but I just had to buy a big truck electic horn to replace existing. My problem is that I can't find the existing horn to rewire into my replacement. Any help would be appreciated. Guess I should have popped the hood before buying the horns. Thanks.
Old 08-09-2006, 10:04 AM
FortyFords's Avatar
FortyFords
FortyFords is offline
you have to remove the inner fenderwell liner to get to them,if memory isn't failing me its the passenger side
Rich
Old 08-09-2006, 10:10 AM
Bear Hunter's Avatar
Bear Hunter
Bear Hunter is offline
You can tap into the factory horn wire behind the fuse box. Use a multimeter to check the wire. On an 04 it is "Yellow with Green Tracer"
If I were you I would put a SPDT mini toggle under your steering column that will allow you to switch between your factory horn and your new electric ones. The position of the switch will determine which horn is sounded when you push the horn button in your steering wheel.
http://www.truckblog.com/story-792-h..._and_air_horns
Old 08-09-2006, 11:32 AM
pistolpete837's Avatar
pistolpete837
pistolpete837 is offline
hey tlamshooter
which horn did you buy? i am interested in doing the same thing.
Old 08-09-2006, 12:00 PM
tlamshooter
Thanks guys. I will have to look at which is easier, I think going into the fuse box might be easier and more room to mount the horns on that side. Like I said, I should have looked before I leapt since my F250 is brand new (bought it last month) I didn't worry about modifying my 96 F150 that I sold to buy the 250. Pistol Pete, I bought the twin horns on this link. But my new truck doesn't have as much room as I had thought for mounting them.
http://www.wolo-mfg.com/elec.htm
Old 08-09-2006, 04:24 PM
pistolpete837
i think i have the same horn on my bronco and im not to impressed with it but hopefully you will have a better experience.
Old 08-09-2006, 07:40 PM
Cobra97Vert's Avatar
Cobra97Vert
Cobra97Vert is offline
here is the one I just bought. Bolts in place of factory and reuses the same wires and mounting, thats why I chose this one. Just got it in, havent had time to install yet.
http://www.stylinconcepts.com/parts..../categoryid/31
clark grizwald
06-30-2017 09:49 AM
panther71
2004 - 2008 F150
05-05-2017 07:33 AM
Auburn_in
01-16-2013 11:57 AM
oskie
01-27-2006 12:38 AM
lee
10-30-2000 12:57 AM
Quick Reply: 06 F250 horn location
