Max. oil temperature?
Originally Posted by seventyseven250
Jim, so are you saying that modern engines have a design flaw the requires aftermarket products to fix?
Originally Posted by jimdandy
I'm not saying anything. Just passing along information. This is a quote from the referenced web site. I checked a couple other sites, Gale Banks Engineering being one of them. The say approximately the same thing. Draw your own conclusions. jd
The ideal operating range for engine oil is 180°F through 200°F.
Oil that exceeds 220°F rapidly loses its ability to lubricate and cool causing accerlerated fatigue and premature component failure.
This may not be applicable to race engines that have their oil changed ever few hours of use, or in other specialty applications. I'm only referring to normal use in a modern stock vehicle.
Of course, now I'm just being argumentative.
I disagree, you are saying something, that's why you put that post there. I have to assume that those sources you reference have their own reasons for the information that they post, possibly selling more aftermarket products. Let's face it, if they told you that your engine didn't need their stuff, you wouldn't buy it.
Maybe what you say about the products is true, pure advertising hype, I don't know, and really don't care. Gale Banks orginization is a very reputable firm, and until I learn otherwise, I will take his information as correct. The man asked a question, I gave him information, and sourced it. He can make up his own mind.
On the other hand, I haven't seen anything from you, or anyone else disputing the figures, or substantuating your own. These figures have been around for years, and are nothing new.
The figures are for a stock engine, racing temps run much higher. jd
I wasn't trying to be glib, if I came across that way, I apologise. You are also correct that I haven't brought forward any references. I'll just restate my two main points and then anyone reading can draw their own conclusions.
- Water does get into oil under normal operation, and boiling it out at temps over 212F is an effective way to remove it.
- Modern engines are designed to operate using modern oils at temperatures between 220 and 295F (according to jimdandy, which I don't despute.)
At least this has been a good discussion that should help people think about oil temps and other related issues.
ontarioford
07-12-2017 04:33 PM
Bigblockboy
04-22-2016 10:05 PM
