Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's
Hard Shifting Tranny
Old 08-03-2006, 10:11 AM
Fast02f150HD's Avatar
Fast02f150HD
Fast02f150HD is offline
Talking Hard Shifting Tranny
I just got a 2002 F-150 Harley Davidson truck, pretty much stock. I have noticed that under "normal" driving the transmission is somewhat smooth going through the gears but when I really jump on it, either from a standing stop or while I am already moving, it shifts extreme hard, especially from 2 -> 3.
Has anyone else experienced these issue? Does anyone have any suggestions? Solenoids maybe? Something else?
Thanks
Old 08-03-2006, 06:51 PM
evo's Avatar
evo
evo is offline
It sounds like the previous owner put a modified valve body in.
Old 08-03-2006, 06:55 PM
Fast02f150HD
What is the advantage/dis-advantages to putting a modified valve body into the transmission? I would think that one would want the shift to be smooth while they are accelerating, especially with the power that this truck has.
Old 08-03-2006, 07:03 PM
evo's Avatar
evo
evo is offline
Sloppy shifts are for the masses. The faster the shift the less friction on the plates. Less heat, extends life of tranny. Not to mention chirping gears is fun.
Old 08-04-2006, 07:36 PM
Stewart_H's Avatar
Stewart_H
Stewart_H is offline
Other than better performance, a modified VB will reduce wear on the tranny clutches.
Sounds like you have a Factory Tech VB (FTVB), or maybe a LFPVB, on your tranny.
Add a higher stall torque converter and you'll have a nice tranny setup for racing!
Stewart
Old 08-04-2006, 07:37 PM
Stewart_H's Avatar
Stewart_H
True, oh so very true!
Stewart
Old 08-11-2006, 07:25 PM
ROADKIL's Avatar
ROADKIL
ROADKIL is offline
I had my truck to the dealer for the same reason, They told me that's the way it was suppose to shift.
Old 03-15-2007, 09:39 AM
petern's Avatar
petern
petern is offline
i have a 2001 hd truck and have the same problem. had a mechanic check and was told the same thing. now i have a leak around my toque converter. i have 56,000 miles on my truck. does anyone know if ford has done any recalls or anything else about this? i dont want to be looking at a rebuild on my tranny already. any ideas?
Old 03-22-2007, 04:05 PM
MikeMM's Avatar
MikeMM
MikeMM is offline
Smile Harley Tranny Problems
Hey,
I had a problem with my Harley between 2nd & 3rd and just installed the Sonnax modulator.
We also found 2 broken springs in the valve body.
Truck is running "Great" for now.
Hope this helped.
Mike
jonc123
06-01-2020 10:32 PM
Ecarlton1991
16
08-19-2011 04:43 PM
morrigj83
1999 to 2016 Super Duty
05-23-2011 11:45 AM
hbonham
06-27-2007 12:13 AM
bobzhereagain
09-18-2003 07:08 PM
Quick Reply: Hard Shifting Tranny
