1961 - 1963 F100 Unibody 1961, 1962 and 1963 Ford F100 Unibody trucks
64 f100 292 motor mounts
Old 09-27-1999, 09:33 AM
frank_1's Avatar
frank_1
frank_1 is offline
Old 08-28-2002, 08:26 PM
mach1me's Avatar
mach1me
mach1me is offline
I have a '64 with a 292, one motor mount front, two rear, out of the truck they look the same. Worn out and bigger than any parts house has. I know they are orignal, part of ford part number readable. No luck finding. This is where I landed looking for HELP! Please.
Old 08-28-2002, 11:07 PM
LxMan1's Avatar
LxMan1
LxMan1 is offline
Did you check the online store on this site? They may have something.
Old 08-28-2002, 11:08 PM
LxMan1's Avatar
LxMan1
LxMan1 is offline
Disreguard, I looked them up and they only have a blank page for them.
Old 08-29-2002, 02:58 AM
Zen_1963_Unibody's Avatar
Zen_1963_Unibody
Zen_1963_Unibody is offline
Over the 39 years that my '63 F100 Unibody has been in the family, it's busted over half a dozen motor mounts. Usually happened when someone was overzealous by shifting from drive to reverse or vise-versa while the truck was still rolling (Cruis-O-Matic trannies hate that and will show it by locking up the rear tires or busting a mount). I've replaced them twice in the 4 years it's been in my possession. Since then, I've added a torque strap, and don't let anyone drive my truck.
They aren't real hard to find, but to find correct ones can be a challenge. I recommend Topp's Auto Supply in Anaheim, California if you want good quality y-block mounts (and many other parts) for good prices. I don't know where you are, but I'm sure you can arrange for them to send you parts. Not even SoCal Pickups in Riverside, CA has the right engine and tranny parts (and they specialize in older Fords!). Topp's has never failed me when I needed something for my 292.
You say the old rubber mounts seem to be too large, well, that's prolly because they are smashed. They also may be foreign-made. There are many y-block mounts out there that are made overseas. They are not the right size, and use inferior bolts.
Topp's mounts are made in the USA, and use only Grade 8 bolts. Check 'em out.
-Zen-
Old 08-29-2002, 06:24 PM
mach1me's Avatar
mach1me
mach1me is offline
Thanks for info,
Intrestred in a number for Topp's auto, please. I'm in Sacramento area. The mounts are orignal, I can read some of old ford pn, and see ford logo,C_TA-60_8-d-yel/C_TT-6068-B-AU, long number. This mount takes a 9/16" x 4" bolt, the one everyone lists for my truck take a 1/2" bolt. Thier books also list front, left or right. Mine has one front and center, two at rear, all the same size. Well the two at rear are smashed and torn. Truck is a July '64 build in San Jose, last month for model year, this could explain why hard to find?
I find this site very intrestring. Thanks Again
Old 08-30-2002, 04:44 AM
Zen_1963_Unibody
In reply to mach1me
Last time I replaced my rear motormounts, they most certainly took a 9/16" x 4" bolt. I've never replaced the front mount on my 292, so I'm not sure if it is the same.
As for getting a number for Topp's, just dial 411, reply Anaheim when they ask you, and ask for Topp's Auto Supply's number. You can also ask for SoCal Pickups' number in Riverside, CA. I know SoCal Pickups has mounts, but I trust Topp's more, myself. I'm sorry I do not remember the numbers off hand, as I moved from California to North Dakota last December.
I see you have a San Jose-built truck! San Jose is my hometown. Unfortunately, my '63 wasn't built there, it was built in Kansas City. Oh well, as long as it wasn't built on a Monday or Friday, built in the US is just fine by me!
-Zen-
Old 08-30-2002, 12:06 PM
LxMan1's Avatar
LxMan1
LxMan1 is offline
Lucky me then, My 63 was built here in Louisville and it is still here today, and always will be!!
Old 09-04-2002, 11:06 AM
IFLEWBY's Avatar
IFLEWBY
IFLEWBY is offline
Contact johns fun hundreds on their web site at www.johnsf-funhundreds where they have the comlete breakdown on the website. You can contact them at 1-800-563-3151 for any questions. I am restoring a 62 f-100 and have ordered all my parts from them.
Old 09-05-2002, 07:23 PM
mach1me's Avatar
mach1me
mach1me is offline
Thanks for a good lead, I had some trouble finding, John'sf-funhundreds, thier site is www.f100.com. The motor mount they show looks good. I emailed them and asked for some measurments.
Thanks Again from
Ken and his 64 F100
Old 09-06-2002, 04:42 AM
Zen_1963_Unibody
That is definitely a very good site. Funny tho, I llived in Anaheim from '99 to '01 and never heard of that place. His prices are fair, but SoCal Pickups in Riverside are cheaper for many items.
The schematics on the website are very handy!
-Zen-
Old 09-10-2002, 09:30 PM
mach1me's Avatar
mach1me
mach1me is offline
I made contact with John’s F - Funhundreds, they have motor mounts in the size I’m looking for. They are in the mail, I’ll make a final post if they are the correct ones. Good price as well, 17.50 ea. Thanks again for the info.
Old 09-20-2002, 10:56 PM
mach1me's Avatar
mach1me
mach1me is offline
Motor mounts came in, just like the orignal, and just the right size.
Thanks again for the help.
Old 09-23-2002, 05:45 PM
1964_mezajd's Avatar
1964_mezajd
1964_mezajd is offline
I'm new to posting a message but not to reading the board messages.
Anyways, I have actually made my own since they were too hard to find and a bit expensive when I found them. The auto parts store wasn't even sure that they would fit when they came in. I tried several parts stores and none had a clue. I used an old tire and cut the forms from the side-walls. I used a utility knife; traced the mounts with a blue ink pen and cut eight round pieces. I stacked 4 on each of the upper mounts and it works great. No more transmission shifting with the homemade supports. I used the lower and outer washer that the original mounts had. Hope this helps anyone out there. My 292 has never worked better.
Robert
Old 08-04-2008, 08:31 PM
kooper909's Avatar
kooper909
kooper909 is offline
Great info in this thread, found it with the search.
The mounts I bought at AutoZone for a '61 were wrong--- they were the same exact ones they list for my '60. They show these rear ones:
They fit great on my '60, but obviously they're not right for a '61.
For some reason Dennis Carpenter lists them this way too. I just placed an order for the correct ones on Johns F-Fun Hundreds. Thanks guys.
Quick Reply: 64 f100 292 motor mounts
