94 2.3l stock gearing ques
Old 07-25-2006, 02:55 PM
prerunner's Avatar
prerunner
prerunner is offline
ok I have a 94 2.3l 5-speed manual and I have been trying to find the stock rear end gears they put and also stock tire size. I have 31in tires on my truck and reageared to 4.10's but I am looking at going to 4.56's. My trucks just to slow on the freeway. I just want to know in 5th what the max speed I can cruise at with 4.56's and still get good mpg. thanks for all the help
Old 07-26-2006, 08:14 AM
TigerDan's Avatar
TigerDan
TigerDan is offline
The higher the number, the lower the ratio. 4.56 gears are lower than 4.10s and will slow it down even more, unless you really want the motor to be winding out at freeway speeds. Acceleration will be great though.
For the stock gear ratio, look at the door tag for the axle code and then decode it here:
https://www.ford-trucks.com/article/...r_Decoder.html
There should also be stock tire size info on the door sticker, probably 215/70-14"
hustler54
1983 - 2012 Ranger & B-Series
16
06-23-2013 06:33 PM
DonnyG77
15
04-21-2009 03:59 AM
elyrain
1999 to 2016 Super Duty
15
12-16-2006 11:41 PM
BootHill
1978 - 1996 Big Bronco
01-13-2005 08:55 PM
DougD
16
07-23-2004 09:03 PM
Quick Reply: 94 2.3l stock gearing ques
