Ignition turns and starts truck with no key why?
For the last few weeks something with my 95 f 250 (351 w auto) hasent been right with the Ignition.I can turn the ignition without the key in and start my truck why is this?Do i need a new one?..what about the key how do i get a new one made if i need one to fit my key?any info will help..thanks
Here's some info on how to do it.
http://www.autozone.com/servlet/UiBr...3d800a9e94.jsp
I got a new one from the Ford dealer with a new set of keys for about $14.00 a few years ago. Your new keys will not match the doors, but if you are worried about this(I just carry both keys), you can get a locksmith to make the door locks match the new ignition keys.
http://www.autozone.com/servlet/UiBroker?ForwardPage=/az/cds/en_us/0900823d/80/0a/9e/94/0900823d800a9e94.jsp
A locksmith should have an 'uncoded ' ignition cyl. and set it to his key. Or they can use a switch already combinated, overlapping the cuts and giving him a new key but still work doors and ign.
Just find a locksmith that has a walk in shop instead of mobile service only, that way there is no service call[img]images/icons/icon14.gif[/img]
Once you get the ignition replaced make sure that you don't have 50 lbs of crap om your key ring, that is what causes the pins to wear out like yours have. Yes, with time from putting the key in and taking it out you will wear the pins down, but its the extra weight on the key ring that ***** the key and accelerates the wear.
on that year it is a common problem for the "ears" on the ignition to break. when that happens sometimes the ignition cylinder will turn without a key. Go to a locksmith with your key and they will key up a new cylinder to your key. That is the best way to fix it and it's not very expensive.
avking2508
07-09-2016 06:47 PM
Mad.Scientist
08-26-2009 12:27 PM
