Old gasoline ?
Old 07-09-2006, 08:02 AM
97F250XLT's Avatar
97F250XLT
97F250XLT is offline
Old gasoline ?
I have some old gas probably 3 years old in a above ground elevated storage tank. The tank probably has 50 gallons in it is it safe to use? Should I add something to it or blend it with 50-50 new and old gas. Or is there a additive that a person could put in it?
Old 07-09-2006, 09:28 AM
04 Heritage's Avatar
04 Heritage
04 Heritage is offline
Very good question.
Old 08-18-2006, 01:38 AM
angus's Avatar
angus
angus is offline
I've burnt older gas than that, but that's in a carb'd vehicle. It wouldn't be a bad idea to dilute 50/50 or lower, and run it through a sediment and water filter, because there's probably condensation in there by now.
Old 08-18-2006, 11:01 AM
rusty70f100's Avatar
rusty70f100
rusty70f100 is offline
I've ran gas like that before. Like was said, I'd run it 50/50 with fresh gas until it's all gone.
Old 08-18-2006, 11:11 AM
jimandmandy's Avatar
jimandmandy
jimandmandy is offline
Drain out any water at the bottom and it should be fine to mix. If it had ethanol in it, the water and ethanol should come off the bottom together, leaving the gasoline on top. There are additives to preserve gas, but they have to be added first, not now.
Jim
Old 08-30-2006, 09:07 PM
chrono4's Avatar
chrono4
chrono4 is offline
The gas in my bronco was about 4 years old, still ran on it. The more gas, the longer it takes to go bad so 50 gal should be ok, but like said change the filter on the tank and run it 50 50.
tlb
04-23-2016 12:21 AM
Old Brown Truck
10-31-2015 10:30 PM
Cabledude
10-13-2014 10:40 PM
sitdog84
05-28-2014 01:44 PM
84espy
17
07-08-2013 08:33 PM
Quick Reply: Old gasoline ?
