WVO and Dino mix
WVO and Dino mix
I am wanting to take advantage of burning a little WVO but dont have the space to make enough Bio to meet my demand and dont want to convert the truck with another tank and heater. Can you mix WVO and Dino to a ratio that you only have to filter the WVO? Or is this like water and oil? I have read a little on making the Bio and was wondering if there is any waste in this process and if so how do you get rid of it? any help would be appreciated.
FABMANDELUX.
Thanks for the info. I seen an additive and process for WVO at www.dieselsecret.comHas anyone used this process? it seemed to be easier / faster.
Do a search of this forum on it, then make up your mind.
FABMANDELUX.
You can get some info about blends (WVO and x) at the infopop forum, under the Straight Vegetable Oil (SVO) as fuel. They also talk about WVO.
A couple of common blends are WVO and gasoline in an 80/20 or 85/15 mix. I personally don't run blends but there is information out there.
Dieselsecret is evil.
Rory
Blends are inherently problematic because you are mixing liquids of differing specific gravity and molecule size together. Mixtures like that tend to seperate into layers so you are only burning one or the other (depending on which layer the pickup in your tank is drawing from) not a mix.
Some here have claimed that they make mixes that dont seperate, maybe so maybe not, I know that the laws science say it shouldn't work.
When you weigh the potential costs, destruction of your engine, against the potential benefits, save a few bucks on fuel, running a mixture doesn't look quite so good.
If you are serious about running WVO do it right, convert the fuel system. If you dont want to convert your truck then learn to make Bio.
i appreciate all of the info. looks like i will learn to make the Bio. i dont want to convert the truck because if i ever trade it in i am looking at another conversion.
i have a 2000 f250. isnt the fuel pump in the tank? i have a spare tank i have installed in the bed of the tank but have it hooked up to just tranfer to the original tank via an electric fuel pump with a tee installed in the filler neck. it is only a 20 gal. tank but that makes a total of 50gal i can haul (further than i can drive without stopping) is there some place that sells these conversions? not real crazy about spending that much money but i realize the returns are good.
Rishsd
Bio-diesel, Propane & Alternative Diesel Engine Fuels
05-18-2013 03:18 AM
fireman660r
04-16-2008 12:50 AM
6.0superduty
03-19-2008 11:44 AM
Orpackrat
10-14-2006 12:03 AM
