Finally today
Old 07-03-2006, 02:04 PM
kennedyford's Avatar
kennedyford
kennedyford is offline
Smile Finally today
Alright today will be the day. Heater works, pump works, cyclone ummm well see. First batch today while I work on the truck.
Old 07-03-2006, 06:39 PM
fabmandelux's Avatar
fabmandelux
fabmandelux is offline
Ok Troy...............It's 4:33, Have you got Bio yet? Really great to see ya get it going. Hope everything goes well
FABMANDELUX.
Old 07-04-2006, 12:00 AM
kennedyford
Nope, spend the rest of the evening modifying my fuel lines and testing the new transmission in the truck..I will have the bio preheating tomarrow at 4pm and add my chemicals at 6 and pump. Then at 7 I will transfer through the cyclone to the holding tank and see what she will do. Nothing is what it seems huh?
Old 07-04-2006, 11:18 AM
adambomb's Avatar
adambomb
adambomb is offline
kennedyford-
What are you doing to mod your fuel lines?
Old 07-04-2006, 11:37 AM
kennedyford
Well I was attempting to do the hutch mod, but I only just replaced steel lines with rubber and installed a pre pump filter and switching valve for my aux tank. I have to go back in and finish the hutch mod and install a pickup pump later.
Old 07-04-2006, 03:15 PM
fabmandelux
Still waiting Troy.................God you "youngsters" are sloooo
FABMANDELUX.
Old 07-04-2006, 11:31 PM
kennedyford
aaargg. didnt get anywhere near 150...leaving the heater on tonight and try in the morning.
Old 07-05-2006, 07:41 PM
kennedyford
Stupid thermostat broke. Wont stay on so I will be rewiring it. Not today again.
Old 07-05-2006, 08:25 PM
cookie88's Avatar
cookie88
cookie88 is offline
Anybody tried using gas heat?
I was looking at the stand and heater for the fish cooker and was thinking it wouldn't be difficult to build a little bigger stand for a water heater tank.
I guess it would be too time intensive since there wouldn't be any way to regulate the heat other than standing there with a thermometer and a hand on the bottle valve.
Old 07-05-2006, 08:37 PM
fabmandelux
Gas flame.....................Methanol vapors..............let's see........BOOM! Sorry, Cookie Just couldn't resist
FABMANDELUX.
Old 07-05-2006, 08:57 PM
cookie88's Avatar
cookie88
cookie88 is offline
It ok. I was putting gas in the wife van the other day and the guy next to me at the pump was smoking a cigarette. We all have our moments.
I would imagine the sparks from a faulty electric element would blow one up just as high. Making one's own fuel is not without it's risks.
Old 07-05-2006, 09:32 PM
bigredtruckmi's Avatar
bigredtruckmi
bigredtruckmi is offline
Wonder what your homeowners insurance would say about the fuel maker??
Old 07-06-2006, 02:08 PM
kennedyford
Thats funny...dang nabbit...Fab what are you using for a thermostat? I was going to direct wire but then I thought solid carbon wont really run through the pumps. Maybe pull the elements out and put in an open barrel? hmm just dont know yet. Youd be proud of my scale....1 bar, 1 plywood balanced. 2lbs weight on one side and equal chemicals on other. Im runnin hillbilly now.
Old 07-06-2006, 02:37 PM
fabmandelux
Appleseed= Sorry, Troy, I just can't help myself this week
Ok,Ok........MY secret.......use an oven thermostat
Watertank eliments are junk! Barely a high-temp cut-off switch! Oven thermostats on the other hand are made to hold the temp +,or - 2-3 deg. Much better! And you can "hang" the temp probe most anywhere.
What's a scale?
FABMANDELUX.
Old 07-06-2006, 05:48 PM
Phydeaux88's Avatar
Phydeaux88
Phydeaux88 is offline
Diesel is not nearly as likely to go BOOM as gasoline, in fact stand back and throw a lit match at diesel and it will likely put the match out.
So if the guy was pumping diesel he is only half crazy, if he was pumping gas he is certifiable
Quick Reply: Finally today
